RacecapturePro MK4 hardware install
Revision as of 19:50, 24 July 2024 by Abdurrehman Akhtar (talk | contribs) (Created page with "=Installation= ==Mounting Orientation== The system can be mounted in various orientations to suit your needs. However, for optimal performance of the accelerometer and gyroscope, it is recommended to mount the system horizontally flat with the indicators facing the driver. After mounting, you can zero out the channels by performing calibration in the Setup section under Accel/Gyro. ''' Recommended Orientation'''<br> Horizontally Flat Indicators facing toward the driv...")
Alternate Orientations
  • Upside Down
  • Vertical / On Edge
Calibration and Remapping
