RacecapturePro MK4 hardware install
Mounting Orientation
Recommended Orientation
Alternate Orientations
- Upside Down
- Vertical / On Edge
Calibration and Remapping
Mounting Dimensions
- 12-pin female M12 connector for analog input devices.
- SMA connector for GPS antenna connection.
- 12-pin female M12 connector for digital input and RPM sensors.
- 6-pin female M8 connector for CAN1, CAN2, and power connections.
- 4-pin female M8 connector for CAN1 and power connections.
M12 Analog / Digital Connectors
9 | Analog/Digital B | Analog 7 | GPIO 3 |
10 | Ground | ||
11 | Ground | ||
12 | Ground |
M8 Connectors 4-Pin CAN1+Power
Pin | Connection | Notes |
1 | CAN 1 low | |
2 | Power | 9-24v / 1A (~12W) |
3 | CAN 1 high | |
4 | Ground |
1 | CAN 1 low | |
2 | CAN 2 low | |
3 | CAN 2 high | |
4 | Ground | |
5 | CAN 1 high | |
