RacecapturePro MK4 hardware install
Mounting Orientation
Recommended Orientation
Alternate Orientations
- Upside Down
- Vertical / On Edge
Calibration and Remapping
Mounting Dimensions
- 12-pin female M12 connector for analog input devices.
- SMA connector for GPS antenna connection.
- 12-pin female M12 connector for digital input and RPM sensors.
- 6-pin female M8 connector for CAN1, CAN2, and power connections.
- 4-pin female M8 connector for CAN1 and power connections.
M12 Analog / Digital Connectors
9 | Analog/Digital B | Analog 7 | GPIO 3 |
10 | Ground | ||
11 | Ground | ||
12 | Ground |
M8 Connectors 4-Pin CAN1+Power
Pin | Connection | Notes |
1 | CAN 1 low | |
2 | Power | 9-24v / 1A (~12W) |
3 | CAN 1 high | |
4 | Ground |
1 | CAN 1 low | |
2 | CAN 2 low | |
3 | CAN 2 high | |
4 | Ground | |
5 | CAN 1 high | |
OBDII CAN cable
SMA Connector
Antenna Placement Guide
Powering
Power Requirements
Voltage | 9-24v |
Current | 1A (~12W) |
Sensor Connectivity
Analog Inputs pins
Channels | 9 analog input channels, with 8 external and 1 internal for monitoring battery or supply voltage |
Voltage Range | 0-5V |
Input Impedance | Greater than 1M ohm |
Voltage Protection | Up to 400V (intermittent) |
ADC Precision | 12-bit |
Maximum Sample Rate | 1000Hz |
Mapping | Can be configured as Raw, using a linear formula, or an interpolated map |
Note: You can use an analog port to monitor the states of 12V switches, lights, or other 5V-12V On/Off devices. It is recommended to use an inline 10K 1/4 watt resistor to ensure proper functioning and protection of the system. The input should be mapped such that a voltage range of 0-3.0V corresponds to a state of 0, and a voltage range of 3.01V and above corresponds to a state of 1. Even when 12V is applied, the system will display a maximum of approximately 5V, ensuring safe monitoring and accurate state detection of the connected devices.
- See our comprehensive Sensor Guide for information on connecting various types of analog sensors.
Frequency / RPM Input
You can connect RPM, wheel speed, and other pulse-type sensors to the RaceCapture/Pro frequency input pins. These inputs are designed to handle various types of frequency-based signals, providing accurate and reliable data for performance monitoring and analysis.
Maximum Sample Rate | 1000Hz (logging to SD card) |
Mapping Supported | The input signals can be mapped to RPM, frequency, or period measurements. |
