Research and Development Platforms
Revision as of 17:44, 28 September 2008 by Brentp (talk | contribs) (→‎Suspension: centered image)
Datsun 240z S30
Our newest test platform, a 1973 240z, lived it's former life performing road race duties. As such, it's received the most amount of attention towards handling and safety.
Specs
Engine
  • 2.4L L24 inline six
  • 4-speed transmission
  • R180 differential
Suspension
  • upgraded sway bars- tubular front, solid rear
  • Koni shocks, race springs
  • 15x8 3 piece race wheels, Toyo R888 225-45-15 tires
Safety/Interior
  • 6 point roll cage
  • Momo steering wheel, Sparco Race seat
Planned upgrades
  • Triple weber 40 DOCE; Cannon manifold
  • 3-2-1 tubular manifold
  • Megajolt Igniton
  • Wilwood 4 piston calipers, 2 piece rotors front
  • Rear disc upgrade
Mission
The 240z will be our track-day workhorse.
Toyota MR2 AW11
Our first test platform, a turbocharged (4AGTE) 1985 MR2 AW11 started it's life that has seen extensive engine and suspension modifications.
The MR2 will specialize in autocross/time-trial sprints.
Specs
Engine
  • 1.6L 4AG 7 rib block
  • Arias pistons, 8.6:1
  • Stainless +1mm valves
  • 16g turbo, custom turbo manifold
  • Megajolt Lite Jr. Ignition; Megasquirt Fuel control
Drivetrain
  • Quaife quick ratio steering rack
  • C52 transmission, Kaaz 1.5 way clutch LSD
  • Fidenza flywheel, Clutchmasters Stage 2 clutch
Suspension
  • Koni 8611 double adjustable shocks
  • Ground control coil over
  • Suspension Techniques front and rear swaybars
  • High and Tight urethane bushings
  • Bump steer correction / roll center adjustment front and rear
  • 15x8 Kosei K1, Hoosier A6 225-45-15
