Ford EDIS technical information
Revision as of 06:37, 20 October 2008 by Brentp (talk | contribs) (added section on adapting machined trigger wheel to OEM crank pulley.)
Ford EDIS general information
Sensor Position
Type Degrees BTDC
EDIS-4 90
EDIS-6 60
EDIS-8 50
Interfacing with OEM Tach
Tach circuit
Trigger Wheel Designs
Adapting OEM trigger wheel
Crank pulley modifications
Alternate coil wiring
The following oscilloscope image shows the current limiting 'feature' of the EDIS module. The EDIS module will automatically adjust the dwell time to charge the coil primary up to a pre-determined current limit.
--insert plot here--
The plot illustrates the effects of active current limiting. The coil driver wired with two primares shows 1/2 the dwell time of the other coil primary, wired normally.
