Ford EDIS technical information
Revision as of 23:01, 21 October 2008 by Brentp (talk | contribs) (Multiple coil primaries per driver: simplified / clarified)
Ford EDIS general information
Sensor Position
Type Degrees BTDC
EDIS-4 90
EDIS-6 60
EDIS-8 50
Interfacing with OEM Tach
Tach circuit
Trigger Wheel Designs
Adapting OEM trigger wheel
Crank pulley modifications
courtesy of Alexander_Monday
courtesy of pope101
Alternate coil wiring
