RaceCapture-Pro MK2
RaceCapture Introduction
Autosport Labs RaceCapture is a powerful Data Acquisition and Control system for motorsport applications, presented at a break-through price.
If you are interested in participating in our beta test program, email us with your request, including a short note explaining how you might benefit from the system, and a bit on your relevant background and experience. This information will help us qualify you as a beta-tester. Previous 'good-citizen' beta-testers will get preferred placement.
Capabilities
Input and Output Channels
RaceCapture offers 20 channels for logging and control, enough to handle complex logging and control tasks.
- 7 dedicated analog input channels
- 3 dedicated frequency input channels
- Measure RPM, wheel speed, or any kind of periodic pulse. One channel is optically isolated for direct connection to ignition coil.
- 4 configurable analog,digital or frequency output channels
- 3 configurable digital channels, settable for input or output
- Receive input from switches; or configure as output and use to activate accessories or drive indicator lamps
- Input for precision 3 channel accelerometer module (+/- 2G per axis, 3G optional)
- Measure and log 3D G-Force in real-time with one of the industry's most accurate and precise accelerometers.
- GPS module input
- Auxiliary serial expansion port
- Interface to future interactive dash/display
Logging
- Store up to 2GB of logging data
Power
- Powerful 48MHz 32 bit ARM processor
- Power to perform high resolution logging and running complex, user-defined logic
Mechanical
- Compact, rugged design with good looks
- On-board Status LEDs
The Intangibles
Flexibility
- Customize logging channels and frequency
- Control outputs based on the logic YOU define
- Powerful PC software to customize, view and analyze data
Infinite Possibilities
- Far more than a data-logging system; Inputs and outputs coupled with a powerful processor yield endless customization
- Open development process, frequent software updates and end-user customizable!
