Ford EDIS technical information
Revision as of 23:41, 23 December 2008 by Brentp (talk | contribs) (Reverted edits by RicdoMouor (Talk); changed back to last version by Brentp)
Ford EDIS general information
Sensor Position
Type Degrees BTDC
EDIS-4 90
EDIS-6 60
EDIS-8 50
Interfacing with OEM Tach
Tach circuit
Trigger Wheel Designs
Adapting OEM trigger wheel
Crank pulley modifications
courtesy of Alexander_Monday
courtesy of pope101
Alternate coil wiring
