Ford EDIS technical information
Ford EDIS general information
SAW Pulse width (uSec) = 1536 - (25.6 x (desired spark advance in degrees)) Range: 64 - 1792us (57.5° BTDC to 10° ATDC) Resolution: 4us (5/32nd of a degree)
Type | Degrees BTDC |
EDIS-4 | 90 |
EDIS-6 | 60 |
EDIS-8 | 50 |
Interfacing with OEM Tach
Trigger Wheel Designs
Adapting OEM trigger wheel
Crank pulley modifications
courtesy of Alexander_Monday
courtesy of pope101
Alternate coil wiring
