Trigger Wheel Designs
Revision as of 18:16, 25 July 2009 by Brentp (talk | contribs) (Starter page)
Crank Pulley Strategies
Adapting Trigger Wheel to Existing Crank Pulley
The most common approach is to mate a pre-made Trigger Wheel to the existing OEM crank pulley. Often the trigger wheel must be mounted on the outboard portion of the crank pulley as there is usually not enough room between the crank pulley and block.
Toyota 4AG Trigger wheel installation
Machining Pattern into Crank Pulley
courtesy of Alexander_Monday
courtesy of pope101
Per Vehicle Installations
