Megajolt
The Megajolt2 Family
The Megajolt2/COP/D family represents the next generation ignition controller platform- succeeding the long running Megajolt Lite Jr. + Ford EDIS ignition system combination.
Philosophy
Rather than create one system to fit all applications, a common software architecture will be leveraged across different hardware platforms tailored to match specific usage models. This approach has the following benefits:
- Simplified hardware design
- Reduced cost and physical size
- Minimal to no hardware customization
Timeline
Beta testing is targeted for Summer/Fall 2009 with limited production by end of year.
Megajolt/2
Summary
Megajolt/2 is a Programmable Crank Fired ignition system designed as a single-unit replacement to the MJLJ + EDIS ignition system.
Capabilities
- 4,6 or 8 cylinders in wasted spark mode
- 4 cylinders in Coil on Plug mode (using standard coil-on-plug modules)
- 10K RPM capable
- 0.1 degree timing resolution
- Dual VR Sensor input
- Crank Sensor + Cam Angle Sensor input
- 4 on-board coil drivers
- Soft and hard rev limit
- Designed to work with commodity OEM sensors and coil packs
- Initial support for 36-1 trigger wheel; other trigger wheel configurations to follow
- up to 16x16 ignition map with linear interpolation
- Dual, on the fly switchable ignition map support
- 4 User defined digital outputs
- 3 analog input channels
- TPS, Temperature and Aux
- Ignition advance correction for Temperature and Aux
- Provision for on-board MAP sensor
- On-board expansion for knock sensor module
- 32 bit 48Mz ARM processor
- USB programming interface
Megajolt/COP
Summary
Megajolt/COP is a Programmable Crank Fired ignition targeted for intelligent coil-on-plug modules or external igniter applications.
Capabilities
- Supported configurations
- Up to 8 cylinders in true coil-on-plug mode
- Up to 12 cylinders in wasted spark mode
- 10K+ RPM capable
- 8 coil driver outputs
- Ignition correction for Temperature and Aux
Megajolt/D
Summary
Programmable ignition system targeted for distributor based ignition
Capabilities
- 4,6,8 cylinders
- 8-10K RPM capable (TBD)
- 1 degree timing resolution (projected)
- Support for standard ignition modules (GM HEI, Ford TFI) and generic igniter support
- Hall effect, optical and reluctor timing input support
- 10x10 ignition map with linear interpolation
- TPS, temperature and Aux input
- 4 User-defined digital outputs
- Processor architecture TBD
