MJLJ V3 Downloads
Revision as of 04:39, 20 July 2009 by Brentp (talk | contribs) (added links for config sw 3.3.2 and firmware 3.3.1)
BETA Released Versions
3.3.0 Beta release provides Aux Input capability for advance correction + user output switching; trigger wheel offset and cranking advance is now settable, plus other misc bug fixes.
CAUTION: This is a BETA release. Test carefully and at your own risk. Preferably bench test this firmware release before testing on a live engine. When testing on a live engine, monitor ignition advance stability and test at low engine load
PC Configuration/Tuning software, version 3.3.2 (Requires controller firmware 3.3.x)
PC Configuration/Tuning software, version 3.3.1 (Requires controller firmware 3.3.x)
PC Configuration/Tuning software, version 3.3.0 (Requires controller firmware 3.3.x)
Controller Firmware, version 3.3.1 (includes firmware programming software)
Controller Firmware, version 3.3.0 (includes firmware programming software)
Current Released Versions
Configuration Software
PC Configuration/Tuning software, version 3.2.1 (May require controller firmware upgrade)
Controller Firmware
Controller Firmware, version 3.2.1 (right-click / save)
Previous Releases
PC Configuration/Tuning software, version 3.2.0 (may require controller firmware upgrade)
PC Configuration/Tuning software, version 3.0.0
Controller Firmware
Controller Firmware, version 3.2.0 (right-click / save)
Controller Firmware, version 3.0.0 (right-click / save)
Beta Releases
The following are Beta releases- test with extreme caution!
PC Configuration/Tuning software, version 3.1.2 beta 3
PC Configuration/Tuning software, version 3.1.1 beta 2
PC Configuration/Tuning software, version 3.1.0 beta 1
Controller Firmware, version 3.1.0 beta 1 (right-click / save)
Controller API specification, version 3.1.0 / 2.7.0
Reference
Schematics
Board
Bill of Materials
Source Code
MJLJ V3.2.1 firmware source
MJLJ V3.0.0 firmware source
Tools
Bootloader firmware for the KX8 processor
This is the bootloader firmware for MJLJ. Burn this first to the KX8 processor, then use this boot loader + PC boot loader software to load the MJLJ S19 record. For more information see Motorola AN2295 App Note
Firmware programming software
This is the PC-based software counterpart to the bootloader firmware, used to update the MJLJ firmware.
Older files
PC Configuration/Tuning software, version 3.0.0 beta 4
PC Configuration/Tuning software, version 3.0.0 beta 3
PC Configuration/Tuning software, version 3.0.0 beta 2
Version 2.0.3 MJLJ Tuning Software (Java) requres Java COMM API installed and configured
