IgnitionDrivers
Revision as of 23:34, 1 February 2011 by Brentp (talk | contribs) (Created page with "=Ignition Driver boards= ==Jolt4 Ignition Driver== The Jolt4 Ignition Driver board groups together 4 Ignition drive transistors such as the [http://www.futureelectronics.com/en...")
The Jolt4 Ignition Driver board groups together 4 Ignition drive transistors such as the Bosch BIP373 , Fairchild ISL9V3040S3ST and so on.
  • Up to 4 ignition drivers supported
  • 10 pin molex connector for ease of use
  • LEDs indicating driver activity (requires additional drive current of 3-6ma)
  • Heat-sinking from bottom of PC board- transistors are soldered down to PC Board.
  • 2.48 x 3.14" board sized to fit our compact, aluminum enclosure (or other enclosure accepting 2.5" width PC Boards)
Connector Pinout
License
This design is released under the Autosport Labs Creative Commons license
Downloads
Revision A Hardware
