RaceCapture-Pro MK2
Revision as of 06:18, 27 April 2012 by Brentp (talk | contribs) (Moar info updates)
Impact
RaceCapture/Pro transcends most traditional "Data Logging" systems by virtue of its powerful processor and emphasis on outputs as well as inputs. The ability to perform data acquisition while controlling other devices and systems, coupled with flexible end-user customization offers a unprecedented level of capability.
Significance
Capabilities
Input and Output Channels
    • Receive input from switches or digital signals; or configure as output and use to activate accessories or drive indicator lamps with fully protected 1A mosfet outputs
    • Measure and log 3D G-force in real-time with one of the industry's most accurate and precise accelerometers.
  • 10Hz GPS module input
      • Plot location, speed and time. Onboard detection of start/finish line for automatic lap count and lap time
  • Auxiliary Serial Port
  • Digital expansion port
    • A high speed port provides the ability to add more analog or digital channels, integrate specialty sensor hardware such as thermocouple amplifiers, and so on
Logging
Power
Input/Output Protection
  • 45v protection on all input pins
  • Analog outputs protected by auto-resettable fuse
  • digital outputs are rated at 1A with self-protected mosfets
Mechanical
  • Compact, rugged design
  • On-board Status LEDs
The Intangibles
Flexibility
  • Desktop software to customize RaceCapture/Pro, view runtime data and analyze data
Infinite Possibilities
  • Fully Open Source System - Open Standards, Open File format. Frequent software updates and end-user customizable!
Board Connections
Images
