RaceCapture-Pro MK2
Revision as of 15:12, 27 April 2012 by Brentp (talk | contribs) (added reference to Lua, added CANbus on possible expansion)
Impact
RaceCapture/Pro transcends most traditional "Data Logging" systems by virtue of its powerful processor and emphasis on outputs as well as inputs. The ability to perform data acquisition while controlling other devices and systems, coupled with flexible end-user customization offers a unprecedented level of capability.
Significance
Capabilities
Input and Output Channels
  • 4 configurable 0-5v analog or frequency output channels
  • 10Hz GPS module input
      • Plot location, speed and time. Onboard detection of start/finish line for automatic lap count and lap time
  • Auxiliary Serial Port
  • Digital expansion port
    • A high speed port provides the ability to add CAN bus expansion, more analog or digital channels, integrate specialty sensor hardware such as thermocouple amplifiers, and so on
Logging
Power
Input/Output Protection
  • 45v protection on all input pins
Mechanical
  • Compact, rugged design
  • On-board Status LEDs
Flexibility
On-board scripting
Some Examples:
Software Connectivity
  • Customize logging channels
  • View Runtime Data
  • Edit custom scripting
Infinite Possibilities
Board Connections
Images
Rev E board with on-board accelerometer module
RaceCapture/Pro with GPS Module
RaceCapture assembled terminal block 3quarter 640.jpg <br.>
