RaceCapturePro Lua Scripting
This page is under construction. Check back soon!
Scripting functions for RaceCapture/Pro
getGpio( port )
Retrieves the state of the GPIO ports
- params
- port: integer 0 - 2
- returns:
- state: 1 = port is high, 0 = port is low
When the port is configured for input mode, a voltage high input (> 2 volts) will read as 1; a voltage low will read as 0. A disconnected port will read as high due to the internal pullup resistor.
When the port is configured as output, the port reads 1 when the port is activated (output transistor is connected to ground) and 0 when the port is deactivated (pullup resistor is active)
setGpio ( port, state )
Sets the state of the GPIO port when the port is configured for output mode.
- params
- port: integer 0 - 2, state - 1 = output active; 0 = output inactive
- returns:
- none
getButton()
- params
- none
- returns
isSDCardPresent
Indicates if an SD card is present in the socket
present isSDCardPresent()
- params
- none
- returns
- present: 1 = SD card is present in socket; 0 = SD card not present
isSDCardWritable()
Indicates if the SD card is writable (lock switch on SD card is active)
- params
- none
- returns
- writable: 1 = SD card is writable; 0 = SD card is not writable
setPwmDutyCycle( port, dutyCyclePct )
- params
- port: PWM / Analog output port 0 - 3
- returns
- none
Sets the duty cycle of the specified PWM / Analog output port to the specified duty cycle percentage
setPwmPeriod( port, period )
- params
- period: The period value
- returns
- none
Sets the period of the specified PWM / Analog output port to the specified period
setAnalogOut( port, voltage )
- params
- returns
- none
Sets the output voltage of the specified PWM / Analog output port to the specified period. A convenience function equivalent to setPwmDutyCycle that translates voltage to PWM percentage.
