RaceCapturePro Lua Scripting
This page is under construction. Check back soon!
Scripting functions for RaceCapture/Pro
getGpio( channel )
- params
- channel: integer 0 - 2
- returns:
setGpio ( channel, state )
- params
- channel: integer 0 - 2, state - 1 = output active; 0 = output inactive
- returns:
- none
getButton()
- params
- none
- returns
isSDCardPresent
Indicates if an SD card is present in the socket
present isSDCardPresent()
- params
- none
- returns
- present: 1 = SD card is present in socket; 0 = SD card not present
isSDCardWritable()
Indicates if the SD card is writable (lock switch on SD card is active)
- params
- none
- returns
- writable: 1 = SD card is writable; 0 = SD card is not writable
- params
- returns
- none
setPwmPeriod( channel, period )
- params
- period: The period value
- returns
- none
- params
- returns
- none
getTimerRpm(channel)
- params
- channel: Timer channel 0 - 3
- returns: RPM value
getTimerPeriodMs(channel)
- params
- returns: millisecond value
getTimerFrequency(channel)
- params
- returns: Frequency in Hz
getTimerRaw(channel)
- params
getAnalog(channel)
- params
- channel: Analog input channel 0 - 7
getAnalogRaw(channel)
Reads the raw analog value for the specified analog input channel.
- params
- returns: The raw value measured by the 10 bit Analog to Digital Converted on the specified analog channel, between 0 - 1023
readSerial(port)
- params
- port: Serial port 0 - 1
- returns: a line of serial data
writeSerial(port, data)
- params
getGpsPosition()
Reads the current position as measured by the attached GPS module coming in firmware 1.2
- params
- none
- returns
getGpsLatitude()
Provides the current latitude as measured by the attached GPS module will be removed in firmware 1.2, replaced with getGpsPosition
- params
- (none)
- returns
- The current latitude in decimal degrees
getGpsLongitude()
Provides the current longitude as measured by the attached GPS module will be removed in firmware 1.2, replaced with getGpsPosition
- params
- (none)
- returns
- The current longitude in decimal degrees
getGpsSpeed()
- params
- (none)
- returns
- The current speed in MPH
getGpsQuality()
- params
- (none)
- returns
getGpsTime()
- params
- (none)
- returns
- The current GPS time value
getLapCount()
- params
- (none)
- returns
getLapTime()
- params
- (none)
- returns
getGpsSec()
- params
- (none)
- returns
getAtStartFinish()
- params
- (none)
- returns
getTimeDiff()
- params
- time 1
- time 2
- returns
getTimeSince
- params
- time 1
- returns
