RaceCapturePro Lua Scripting
Revision as of 07:22, 11 May 2013 by Brentp (talk | contribs) (added more documentation)
This page is under construction. Check back soon!
Scripting functions for RaceCapture/Pro
getGpio( channel )
  • params
    • channel: integer 0 - 2
  • returns:
setGpio ( channel, state )
  • params
    • channel: integer 0 - 2, state - 1 = output active; 0 = output inactive
  • returns:
    • none
getButton()
  • params
    • none
  • returns
isSDCardPresent
Indicates if an SD card is present in the socket
present isSDCardPresent()
  • params
    • none
  • returns
    • present: 1 = SD card is present in socket; 0 = SD card not present
isSDCardWritable()
Indicates if the SD card is writable (lock switch on SD card is active)
  • params
    • none
  • returns
    • writable: 1 = SD card is writable; 0 = SD card is not writable
  • params
  • returns
    • none
setPwmPeriod( channel, period )
  • params
    • period: The period value
    • returns
  • none
  • params
    • returns
  • none
getTimerRpm(channel)
  • params
    • returns: RPM value
getTimerPeriodMs(channel)
  • params
    • returns: millisecond value
getTimerFrequency(channel)
  • params
    • returns: Frequency in Hz
getTimerRaw(channel)
  • params
getAnalog(channel)
  • params
getAnalogRaw(channel)
Reads the raw analog value for the specified analog input channel.
  • params
    • returns: The raw value measured by the 10 bit Analog to Digital Converted on the specified analog channel, between 0 - 1023
readSerial(port)
  • params
    • port: Serial port 0 - 1
    • returns: a line of serial data
writeSerial(port, data)
  • params
getGpsPosition()
Reads the current position as measured by the attached GPS module coming in firmware 1.2
  • params
    • none
  • returns
getGpsLatitude()
Provides the current latitude as measured by the attached GPS module will be removed in firmware 1.2, replaced with getGpsPosition
  • params
    • (none)
  • returns
    • The current latitude in decimal degrees
getGpsLongitude()
Provides the current longitude as measured by the attached GPS module will be removed in firmware 1.2, replaced with getGpsPosition
  • params
    • (none)
  • returns
    • The current longitude in decimal degrees
getGpsSpeed()
  • params
    • (none)
  • returns
    • The current speed in MPH
getGpsQuality()
  • params
    • (none)
  • returns
getGpsTime()
  • params
    • (none)
  • returns
    • The current GPS time value
getLapCount()
  • params
    • (none)
  • returns
getLapTime()
  • params
    • (none)
  • returns
getGpsSec()
  • params
    • (none)
  • returns
getAtStartFinish()
  • params
    • (none)
  • returns
getTimeDiff(time1, time2)
  • params
    • time1
    • time2
  • returns
getTimeSince(time)
  • params
    • time
  • returns
getAccel(channel)
  • params
    • channel
  • returns
    • The accelerometer value scaled to actual G force, averaged across 10 samples
getAccelRaw(channel)
Reads the raw ADC value of the specified accelerometer channel
  • params
    • channel
  • returns
    • The raw accelerometer value, averaged across 10 samples
startLogging()
Begins a logging session
  • params
    • (none)
  • returns
    • (none)
stopLogging()
  • params
    • (none)
  • returns
    • (none)
setLed(led, state)
  • params
    • led (1-3)
  • returns
    • (none)
flashLoggerConfig()
  • params
    • (none)
  • returns
    • (none)
setAnalogSampleRate(channel, rate)
Sets the sample rate for the specified channel
  • params
    • channel
    • sampleRate
  • returns
    • (none)
getAnalogSampleRate()
Gets the sample rate for the specified channel
  • params
    • (none)
  • returns
    • (none)
setAnalogScaling(channel, scaling)
Sets the linear analog scaling value for the specified channel
  • params
    • channel: the analog channel
    • scaling: the scaling value
  • returns
    • (none)
getAnalogScaling(channel)
Gets the linear analog scaling value for the specified channel
  • params
  • returns
    • the scaling value
setPwmClockFrequency(freq)
  • params
  • returns
    • (none)
getPwmClockFrequency()
  • params
    • (none)
  • returns
setPwmSampleRate(channel, rate)
Sets the sample rate for the specified PWM channel
  • params
    • channel: the PWM channel
    • rate: the sample rate to set
  • returns
    • (none)
getPwmSampleRate(channel)
Gets the PWM sample rate for the specified PWM channel
  • params
  • returns
    • rate: the currently configured sample rate
setPwmOutputConfig(channel, config)
Sets the output configuration for the specified PWM channel. Note, the hardware dip switch settings must match the configuration set here.
  • params
    • config: the PWM configuration. 0 = analog output; 1 = PWM output
getPwmOutputConfig(channel)
Gets the output configuration for the specified PWM channel. Note, the hardware dip switch settings must match the value returned here
  • params
    • channels: the PWM channel
  • returns
setPwmLoggingConfig(channel, config)
Sets the logging configuration for the specified PWM channel
  • params
    • channel : the PWM channel 0 - 3
    • config: the logging configuration. 0 = PWM period; 1 = PWM duty cycle; 2 = PWM volts
  • returns
    • (none)
getPwmLoggingConfig(channel)
Gets the logging configuration for the specified PWM channel
  • params
  • return
setPwmStartupDutyCycle(channel, dutyCycle)
Sets the PWM duty cycle for the specified channel applied at system start-up.
  • params
    • dutyCycle: the duty cycle, 0 - 100
getPwmStartupDutyCycle(channel)
Gets the PWM duty cycle for the specified channel applied at system start-up.
  • params
  • returns
setPwmStartupPeriod(channel, period)
Sets the PWM period for the specified channel at system start-up.
  • params
    • channel: the PWM channel 0 - 3
    • period: the PWM period todo: define period units
  • returns
    • (none)
getPwmStartupPeriod(channel)
Gets the PWM period for the specified channel at system start-up.
  • params
  • returns
setPwmVoltageScaling(channel, scaling)
Sets the voltage scaling for the specified channel at system start-up.
  • params
  • returns
    • (none)
getPwmVoltageScaling(channel)
Gets the voltage scaling for the specified channel at system start-up.
  • params
  • returns
    • (none)
setGpsInstalled
getGpsInstalled
setGpsStartFinish
getGpsStartFinish
setGpsPositionSampleRate
getGpsPositionSampleRate
setGpsSpeedSampleRate
getGpsSpeedSampleRate
setGpsTimeSampleRate
getGpsTimeSampleRate
setLapCountSampleRate
getLapCountSampleRate
setLapTimeSampleRate
getLapTimeSampleRate
setGpioSampleRate
getGpioSampleRate
setGpioConfig
getGpioConfig
setTimerSampleRate
getTimerSampleRate
setTimerConfig
getTimerConfig
setTimerPulsePerRevolution
getTimerPulsePerRevolution
setTimerDivider
getTimerDivider
calculateTimerScaling
getTimerScaling
setAccelInstalled
getAccelInstalled
setAccelSampleRate
getAccelSampleRate
setAccelConfig
getAccelConfig
setAccelChannel
getAccelChannel
setAccelZeroValue
getAccelZeroValue
calibrateAccelZero
