Sequential shift light
Revision as of 05:52, 10 February 2014 by Brentp (talk | contribs) (WIP for shift light documentation)
Summary
The Sequential Shift Light is compact 4.2" x 0.5" display made up of 14 LEDs in a 3 stage array.
LED configuration
  • 6 green LEDs comprise the outer segments, wired together
  • 6 yellow LEDs comprise the middle segments, wired together
  • 2 red LEDs are in the center, wired together
Electrical Connections
  • +5v common power
  • 3 triggers to activate each color segment
Physical Features
  • All surface mount construction for ruggedness and a smooth bottom, ideal for mounting with double stick foam tape.
RaceCapture/Pro
Megajolt
Technical information
