RaceCapturePro Lua Scripting
Revision as of 18:27, 9 March 2014 by Brentp (talk | contribs) (added header sections)
Example Scripts and How-Tos
[[RaceCapturePro Lua Scripting Examples|Lua Scripting Examples]
getGpio( channel )
  • params
    • channel: integer 0 - 2
  • returns:
setGpio ( channel, state )
  • params
    • channel: integer 0 - 2, state - 1 = output active; 0 = output inactive
  • returns:
    • none
getButton()
  • params
    • none
  • returns
PWM / Analog Output functions
  • params
  • returns
    • none
setPwmPeriod( channel, period )
  • params
    • period: The period value
    • returns
  • none
  • params
    • returns
  • none
Timer / RPM Sensor Functions
getTimerRpm(channel)
  • params
    • returns: RPM value
getTimerPeriodMs(channel)
  • params
    • returns: millisecond value
getTimerFrequency(channel)
  • params
    • returns: Frequency in Hz
getTimerRaw(channel)
  • params
Analog Sensor Functions
getAnalog(channel)
  • params
getAnalogRaw(channel)
Reads the raw analog value for the specified analog input channel.
  • params
    • returns: The raw value measured by the 10 bit Analog to Digital Converted on the specified analog channel, between 0 - 1023
getAccel(channel)
  • params
    • channel (0 - 2 for accelerometer, 3 for yaw gyro sensor)
  • returns
getAccelRaw(channel)
  • params
  • returns
    • The raw accelerometer value
GPS Sensor Functions
getGpsPos()
  • params
    • none
  • returns
getGpsSpeed()
  • params
    • (none)
  • returns
    • The current speed in MPH
getGpsQuality()
  • params
    • (none)
  • returns
getGpsTime()
  • params
    • (none)
  • returns
    • The current GPS time value
getGpsDist()
  • params
    • (none)
  • returns
    • The distance, in Miles
getLapCount()
  • params
    • (none)
  • returns
getLapTime()
  • params
    • (none)
  • returns
getGpsSec()
  • params
    • (none)
  • returns
getAtStartFinish()
  • params
    • (none)
  • returns
getTimeDiff(time1, time2)
  • params
    • time1
    • time2
  • returns
getTimeSince(time)
  • params
    • time
  • returns
CAN Bus functions
initCAN()
  • params
  • returns
    • 1 if successful, 0 if initialization fails.
txCAN()
  • params
Example:
id = 1234
ext = 0
data = [11,22,33]
res = txCAN(id, ext, data)
rxCAN()
  • params
    • timeout (optional). read timeout in milliseconds
  • returns
If no CAN message was received, the function returns NIL
Example:
id, ext, data = rxCAN(100) --100ms timeout
  println("CAN rx: " ..id .." " ..data[0]) --print ID and first element of received message
setCANfilter()
  • params
    • filter ID (0-5). Up to 6 filters are supported. Typically you will use filter ID 0-1.
    • filter Pattern value for CAN filter
  • returns
  • 1 for success, 0 for fail
setCANMask()
available in firmware 2.0 Sets the specified CAN filter Mask, to ignore messages with a particular address. Must use in combination with setCANFilter() to set a complete filter and mask
  • params
    • Mask (0-1). Up to 2 masks are supported. Typically you will use mask 0.
    • filter Pattern value for CAN mask
  • returns
readOBD2()
  • params
  • returns
Logger Control Functions
startLogging()
Begins a logging session
  • params
    • (none)
  • returns
    • (none)
stopLogging()
  • params
    • (none)
  • returns
    • (none)
setLed(led, state)
  • params
    • led (1-3)
    • state : 1 = on, 0 = off
  • returns
    • (none)
readSerial(port)
  • params
    • port: Serial port 0 - 1
    • returns: a line of serial data
writeSerial(port, data)
  • params
flashLoggerConfig()
  • params
    • (none)
  • returns
    • (none)
setAnalogSampleRate(channel, rate)
Sets the sample rate for the specified channel
  • params
    • channel
    • sampleRate
  • returns
    • (none)
getAnalogSampleRate()
Gets the sample rate for the specified channel
  • params
    • (none)
  • returns
    • (none)
setPwmClockFrequency(freq)
  • params
  • returns
    • (none)
getPwmClockFrequency()
  • params
    • (none)
  • returns
setPwmSampleRate(channel, rate)
Sets the sample rate for the specified PWM channel
  • params
    • channel: the PWM channel
    • rate: the sample rate to set
  • returns
    • (none)
getPwmSampleRate(channel)
Gets the PWM sample rate for the specified PWM channel
  • params
  • returns
    • rate: the currently configured sample rate
setGpsSampleRate
Sets the sample rate for GPS logging features
  • params
    • sampleRate - sample rate in Hz. Function has no effect if the specified value does not match a supported sample rate.
  • returns
    • (none)
getGpsSampleRate
  • params
    • (none)
  • returns
  • sampleRate - the configured sample rate, in Hz
setGpioSampleRate
Sets the sample rate for the specified GPIO channel
  • params
    • channel - a supported GPIO channel (0 - 2)
  • returns
    • (none)
getGpioSampleRate
Gets the sample rate for the specified GPIO channel
  • params
    • (none)
  • returns
setGpioConfig(channel, config)
Sets the input/output configuration for the specified GPIO channel
  • params
    • config - 0 = input mode; 1 = output mode. Note, hardware jumpers must also be set to reflect configuration
  • returns
    • (none)
getGpioConfig
Gets the input/output configuration for the specified GPIO channel
  • params
  • returns
setTimerSampleRate
Sets the sample rate for the specified timer channel
  • params
    • channel - a supported timer channel (0 - 2)
  • returns
    • (none)
getTimerSampleRate
Gets the sample rate for the specified timer channel
  • params
    • (none)
  • returns
setAccelSampleRate
Sets the sample rate for the specified accelerometer or gyro channel
  • params
    • channel - a supported channel (0,1,2 for accelerometer; 4 for yaw sensor gyro)
  • returns
    • (none)
getAccelSampleRate
Gets the sample rate for the specified accelerometer or gyro channel
  • params
    • a supported channel (0,1,2 for accelerometer; 4 for yaw sensor gyro)
  • returns
calibrateAccelZero
  • params
    • (none)
  • returns
    • (none)
setGpsStartFinish(latitude, longitude, target)
Sets the start/finish line target, used for lap time calculations.
  • params
    • latitude - latitude in decimal degrees
    • longitude - longitude in decimal degrees
    • target - radius of GPS target, in degrees
  • returns
    • (none)
latitude, longitude, target = getGpsStartFinish()
Gets the start/finish line target, used for lap time calculations.
  • params
    • (none)
  • returns
Virtual Channels
addChannel()
available in firmware 2.0 Adds a virtual channel. This virtual channel remains in memory during runtime; it is not persisted in the configuration. Up to 10 virtual channels can be created.
  • params
    • name: The name of the channel. Must be a channel name known to the system, up to 10 characters long.
  • returns
    • the Id of the new virtual channel, or nil if the virtual channel could not be created.
setChannel()
  • params
    • Id: the ID of the channel provided by addChannel()
    • Value: the new value to set for the virtual channel
Example:
id = addChannel("EGT", 1) --channel name EGT must exist in the list of known channels
   temp = temp * 1000
