RaceCapturePro Lua Scripting
Example Scripts and How-Tos
getGpio( channel )
- params
- channel: integer 0 - 2
- returns:
setGpio ( channel, state )
- params
- channel: integer 0 - 2, state - 1 = output active; 0 = output inactive
- returns:
- none
getButton()
- params
- none
- returns
PWM / Analog Output functions
- params
- returns
- none
setPwmPeriod( channel, period )
- params
- period: The period value
- returns
- none
- params
- returns
- none
Timer / RPM Sensor Functions
getTimerRpm(channel)
- params
- channel: Timer channel 0 - 3
- returns: RPM value
getTimerPeriodMs(channel)
- params
- returns: millisecond value
getTimerFreq(channel)
- params
- returns: Frequency in Hz
getTimerRaw(channel)
- params
Analog Sensor Functions
getAnalog(channel)
- params
- channel: Analog input channel 0 - 7
getAnalogRaw(channel)
Reads the raw analog value for the specified analog input channel.
- params
- returns: The raw value measured by the 10 bit Analog to Digital Converted on the specified analog channel, between 0 - 1023
getAccel(channel)
- params
- channel (0 - 2 for accelerometer, 3 for yaw gyro sensor)
- returns
getAccelRaw(channel)
- params
- returns
- The raw accelerometer value
GPS Sensor Functions
getGpsPos()
- params
- none
- returns
getGpsSpeed()
- params
- (none)
- returns
- The current speed in MPH
getGpsQuality()
- params
- (none)
- returns
getGpsTime()
- params
- (none)
- returns
- The current GPS time value
getGpsDist()
- params
- (none)
- returns
- The distance, in Miles
getLapCount()
- params
- (none)
- returns
getLapTime()
- params
- (none)
- returns
getGpsSec()
- params
- (none)
- returns
getAtStartFinish()
- params
- (none)
- returns
getTimeDiff(time1, time2)
- params
- time1
- time2
- returns
getTimeSince(time)
- params
- time
- returns
CAN Bus functions
initCAN( baud )
- params
- returns
- 1 if successful, 0 if initialization fails.
txCAN( id, isExtended, data )
- params
Example:
id = 1234 ext = 0 data = {11,22,33} res = txCAN(id, ext, data)
rxCAN( timeout )
- params
- timeout (optional). read timeout in milliseconds
- returns
If no CAN message was received, the function returns NIL
Example:
id, ext, data = rxCAN(100) --100ms timeout if id ~= nil then println("CAN rx: " ..id .." " ..data[0]) --print ID and first element of received message end
setCANfilter( filterId, filterPattern )
- params
- filter ID (0-5). Up to 6 filters are supported. Typically you will use filter ID 0-1.
- filter Pattern value for CAN filter
- returns
- 1 for success, 0 for fail
setCANMask( maskId, maskPattern )
available in firmware 2.0 Sets the specified CAN filter Mask, to ignore messages with a particular address. Must use in combination with setCANFilter() to set a complete filter and mask
- params
- Mask (0-1). Up to 2 masks are supported. Typically you will use mask 0.
- filter Pattern value for CAN mask
- returns
readOBD2( PID )
- params
- returns
Logger Control Functions
onTick()
- params:
- (none)
- returns:
- (none)
Example:
setTickRate(rate)
- params
- rate: The rate the onTick() function is called, in Hz. Max tick rate is 30Hz.
- returns
- (none)
startLogging()
Begins a logging session
- params
- (none)
- returns
- (none)
stopLogging()
- params
- (none)
- returns
- (none)
setLed( led, state )
- params
- led (1-3)
- state : 1 = on, 0 = off
- returns
- (none)
readSerial( port )
- params
- port: Serial port 0 - 1
- returns: a line of serial data
writeSerial( port, data )
- params
flashLoggerCfg()
- params
- (none)
- returns
- (none)
setPwmClockFreq( freq )
- params
- returns
- (none)
getPwmClockFreq()
- params
- (none)
- returns
calibrateImuZero()
- params
- (none)
- returns
- (none)
Virtual Channels
addChannel( name, sampleRate )
available in firmware 2.0 Adds a virtual channel. This virtual channel remains in memory during runtime; it is not persisted in the configuration. Up to 10 virtual channels can be created.
- params
- name: The name of the channel. Must be a channel name known to the system, up to 10 characters long.
- returns
- the Id of the new virtual channel, or nil if the virtual channel could not be created.
- params
- Id: the ID of the channel provided by addChannel()
- Value: the new value to set for the virtual channel
Example:
id = addChannel("EGT", 1) --channel name EGT must exist in the list of known channels function onTick() temp = getAnalog(0) --read analog channel 0 temp = temp * 1000 setChannel(id, temp) --sets the virtual channel value end
