Ford EDIS technical information
Ford EDIS general information
The Ford EDIS system consists of a controller module, coil packs and a crank trigger wheel + sensor. Running alone, the EDIS module will fire the spark plugs at 10 degrees BTDC, operating in it's "limp home mode".
SAW Pulse width (uSec) = 1536 - (25.6 x (desired spark advance in degrees)) Range: 64 - 1792us (57.5° BTDC to 10° ATDC) Resolution: 4us (5/32nd of a degree)
| Type | Degrees BTDC |
| EDIS-4 | 90 |
| EDIS-6 | 60 |
| EDIS-8 | 50 |
With the Engine at TDC, the sensor should be positioned 'N' degrees before the missing tooth. Make sure you take into account the rotation of the engine: clockwise or counter-clockwise when determining your sensor mounting.
For example: On an EDIS-4 application with the engine at Top Dead Center (TDC)- if the missing tooth is aligned with TDC (pointing up, or aligned with the crank pulley key), the sensor should be aligned with the center of the tooth 90 degrees BTDC. If this was a typical clockwise rotating engine, the sensor would be positioned 90 degrees to the left side of the crank sensor (9 o'clock position), when viewed facing the crank.
Interfacing with OEM Tach
