Ford EDIS technical information
Revision as of 16:01, 26 February 2007 by Brentp (talk | contribs) (added clarification for cylinder #1)
Ford EDIS general information
The Ford EDIS system consists of a controller module, coil packs and a crank trigger wheel + sensor. Running alone, the EDIS module will fire the spark plugs at 10 degrees BTDC, operating in it's "limp home mode".
Sensor Position
Type Degrees BTDC
EDIS-4 90
EDIS-6 60
EDIS-8 50
Interfacing with OEM Tach
Tach circuit
