RaceCapturePro Downloads
RaceCapture App
- For MK1 and MK2 versions of RaceCapture/Pro
- MK1 users ensure you have updated to the latest V2 firmware.
Windows
Mac OS X
Mac installer coming soon!
Linux
Packages coming soon!
Mobile App
USB Driver
- OS X: No driver needed
- Linux: No driver needed
RaceCapture/Pro MK2
Firmware
How to update MK2 Firmware
Save your configuration
- Press the 'Configuration' button to navigate to the configuration section.
- On the left menu, select Firmware
- On the firmware screen, press the button "Update Firmware"
- Navigate to the firmware file ending in ".ihex"
- Select this file. The firmware will update and show a percentage progress indicator.
- If there is a problem detecting RaceCapture/Pro, unplug/replug and restart the app.
Alternative method
- While holding down the button on RaceCapture/Pro, power it up by plugging in to USB.
- You should observe a rapidly flashing red LED on the unit: it is in bootloader mode.
- Navigate to the configuration/firmware update screen, select the firmware file and update the firmware.
RaceCapture/Pro MK1
Firmware
The 2.7.6 firmware for MK1 is considered 'stable beta' - We feel it's much better quality than the previous 1.2.x firmware and RaceAnalyzer combination, but since it is the first V2 firmware and app release for MK1, we are officially calling it Beta. Please visit the Discussion / support forum for help.
MK1 Bootloader Releases
Firmware update utility
