CAN Bus database
Revision as of 07:32, 20 February 2015 by Brentp (talk | contribs) (→Megasquirt CAN ( MS2/MS3/MS3 Pro ))
CAN bus mappings by OEM ECU and aftermarket device
- Baud Rate: 1MB (Configurable in Megasquirt)
- Values in big endian format
- Default base CAN id: 1520
Megasquirt CAN | ||||||
Channel | Units | CAN Id | Offset (bytes) | Length (bytes) | Conversion | Notes |
RPM | RPM | 1520 | 6 | 2 | (B6 * 256) + B7 | |
IgnTiming | Degrees | 1521 | 0 | 2 | ((B0 * 256) + B1) / 10 | |
AFR | AFR | 1521 | 4 | 2 | ((B4 * 256) + B5) / 10 | Legacy AFR1 (Deprecated on MS3) - to use AFR2 specify offset 6 |
MAP | kPa | 1522 | 2 | 2 | ((B2 * 256) + B3) / 10 | |
MAT | F | 1522 | 4 | 2 | ((B4 * 256) + B5) / 10 | |
EngineTemp | F | 1522 | 6 | 2 | ((B6 * 256) + B7) / 10 | |
TPS | % | 1523 | 0 | 2 | ((B0 * 256) + B1) / 10 | |
Knock | % | 1524 | 0 | 2 | ((B0 * 256) + B1) / 10 | Indication of knock input |
AFR | % | 1551 | 0 | 1 | B0 / 10 | AFR for cylinder #1 (MS3+ compatible) - add 1 to offset for subsequent AFR inputs |
BMW E46
- Baud Rate: 500K
BMW E46 (including M3) | ||||||
TPS | % | 809 | 6 | 1 | (B6 / 255) | |
EngineTemp | C | 809 | 2 | 1 | (B2 * 0.75) - 48.373 | Convert to Farenheight: (temperatureC * 1.8) + 32 |
OilTemp | C | 1349 | 5 | 1 | B5 - 48.373 | Convert to Farenheight: (temperatureC * 1.8) + 32 |
RPM | 790 | 3-4 | 1 | ((B4 * 256) + B3) / 6.4 |
