CAN bus mappings by OEM ECU and aftermarket device
Megasquirt CAN ( MS2/MS3/MS3 Pro )
Installation instructions
Megasquirt CAN
Channel
Units
CAN Id
Offset (bytes)
Length (bytes)
Conversion
Notes
1520
6
2
(B6 * 256) + B7
IgnTiming
Degrees
1521
0
2
((B0 * 256) + B1) / 10
AFR
AFR
1521
4
2
((B4 * 256) + B5) / 10
Legacy AFR1 (Deprecated on MS3) - to use AFR2 specify offset 6
MAP
kPa
1522
2
2
((B2 * 256) + B3) / 10
MAT
F
1522
4
2
EngineTemp
F
1522
6
2
((B6 * 256) + B7) / 10
TPS
1523
0
2
EngineTemp
F
1522
6
2
Knock
1524
0
2
Indication of knock input
AFR
1551
0
1
B0 / 10
AFR for cylinder #1 (MS3+ compatible) - add 1 to offset for subsequent AFR inputs
BMW E46
BMW E46 (including M3)
Channel
Units
CAN Id
Offset (bytes)
Length (bytes)
Conversion
Notes
TPS
809
6
1
(B6 / 255)
EngineTemp
C
809
2
1
(B2 * 0.75) - 48.373
Convert to Farenheight: (temperatureC * 1.8) + 32
OilTemp
C
1349
5
1
B5 - 48.373
790
3-4
1
((B4 * 256) + B3) / 6.4
MBE Systems 992 (Locked Caterham mode)
Channel
Units
CAN Id
Offset (bytes)
Length (bytes)
Conversion
Notes
