Sequential shift light
Summary
The Sequential Shift Light is a compact 4.2" x 0.5" display made up of 14 LEDs in a 3 stage array.
LED configuration
  • 6 green LEDs comprise the outer segments, wired together
  • 6 yellow LEDs comprise the middle segments, wired together
  • 2 red LEDs are in the center, wired together
Physical Features
  • All surface mount construction for ruggedness and a smooth bottom, ideal for mounting with double stick foam tape.
Electrical Connections
  • +5v common power
  • 3 triggers to activate each color segment
RaceCapture/Pro
Hardware Configuration
  • MK1 only Ensure all 3 internal Digital Input/Output jumpers on the RaceCapture/Pro board are set to output mode. Refer to the Installation Guide for details.
  • Connect the Green, Yellow and Red connections from the Sequential Shift light board to Digital Input/Output 1,2,3 respectively.
  • Connect the V connection to either:
    • The +5v voltage reference
    • A separate 5V power supply
    • 12v with an extra current limiting resistor you supply. (See Diagram)
Software Configuration
  • Launch the RaceAnalyzer Software
  • Connect RaceCapture/Pro to your computer.
  • Read the current configuration from RaceCapture/Pro.
  • In the RaceCapture/Pro configuration set the GPIO ports to output mode.
Lua Script
The Lua Script defines the logic for reading the sensor inputs and controlling the various outputs.
  • In RaceAnalyzer, navigate to the scripting window
  • Paste the following code into the window
    • Change the 5000, 6000 and 7000 values to the shift light threshold you prefer.
  • Press 'write script' to write the script back to RaceCapture/Pro
  • Power-cycle (unplug/replug) RaceCapture/Pro to activate the script.
setTickRate(15)
	local r = getTimerRpm(0)
  • Tip - you can perform the setup on the bench just using USB power.
Megajolt
These instructions apply to all versions of the Megajolt system.
Hardware connections
  • Connect the Sequential Shift Light board as follows:
    • Green to PGM3
    • Yellow to PGM4
    • Red to Shift Light output
  • Voltage supply (V) to either
    • The +5v voltage reference output
  • Launch the Megajolt Configuration Software and read the configuration from the controller
  • In the user output screen, set the indicator points you want for the Green, Yellow and Red connections.
  • Write the configuration back to the Megajolt controller.
More information
Technical Reference
