RaceCapturePro2 QuickStart
Prerequisites
Quick Start
  5. Open the RaceCapture application.
  6. Click on 'Dashboard'
  7. Click on the bottom right arrow three times, which will display the digital dash. You should see the Utc and Interval channels changing, which means data is being transmitted over USB.
  4. Once the tracks have been selected, write the updated configuration using the Rc appwrite config.png button in the lower left.
ProTip: Periodically click the update button Update from cloud.png to pull down the latest set of race track configurations.
Setting up Bluetooth
  1. Complete the Quick Start steps above, leaving RaceCapture/Pro connected to your computer
  2. Connect the Bluetooth module to the inner of the two RaceCapture/Pro ports on the same side the USB cable connects to
  3. Open the Race Capture app
  4. Click on the top left 'Menu' button
  5. Click on 'Configuration'
  6. Click on 'Wireless' in the list of options on the left
  7. Click the toggle to the right of 'Bluetooth'
  8. Click the 'Write Config' button on the bottom left (down array pointing to a RaceCapture/Pro)
Set up Android tablet/phone
    3. Default password is 1234
  2. Install the Race Capture app on your Android device from the Google Play Store
  3. Open the RaceCapture app, tap the screen until the RaceCapture logo show up at the top.
  4. Tap the Bluetooth icon at the top right
  5. Select RaceCapture/Pro
  6. After a few seconds you should see a 'Connected to RaceCapture/Pro' message and data will be transmitting to your tablet.
    1. The green light on the Bluetooth module should be solid and not flashing
Verify connectivity
  1. Swipe to the digital dash screen and you should see values changing. Pick up your RaceCapture/Pro and move it around, you should see even more sensors changing!
