RaceCapturePro Lua Scripting
Example Scripts and How-Tos
Lua Scripting Examples
getGpio( channel )
  • params
    • channel: integer 0 - 2
  • returns:
setGpio ( channel, state )
  • params
    • channel: integer 0 - 2, state - 1 = output active; 0 = output inactive
  • returns:
    • none
getButton()
  • params
    • none
  • returns
PWM / Analog Output functions
  • params
  • returns
    • none
setPwmClockFreq( frequency )
  • params
  • returns
    • none
  • params
    • returns
  • none
Timer / RPM Sensor Functions
getTimerRpm(channel)
  • params
    • channel: Timer channel 0 - 2
    • returns: RPM value
getTimerPeriodMs(channel)
  • params
    • returns: millisecond value
getTimerFreq(channel)
  • params
    • returns: Frequency in Hz
getTimerRaw(channel)
  • params
Analog Sensor Functions
getAnalog(channel)
  • params
      • Note: channel 7 is internally dedicated to battery voltage.
getImu(channel)
  • params
    • channel (0 - 2 for accelerometer, 3 for yaw gyro sensor)
  • returns
getImuRaw(channel)
  • params
  • returns
    • The raw accelerometer value
GPS Sensor Functions
getGpsPos()
  • params
    • none
  • returns
getGpsSpeed()
  • params
    • (none)
  • returns
    • The current speed in MPH
getGpsQuality()
  • params
    • (none)
  • returns
getGpsTime()
  • params
    • (none)
  • returns
    • The current GPS time value
getGpsDist()
  • params
    • (none)
  • returns
    • The distance, in Miles
getLapCount()
  • params
    • (none)
  • returns
getLapTime()
  • params
    • (none)
  • returns
getGpsSec()
  • params
    • (none)
  • returns
getAtStartFinish()
  • params
    • (none)
  • returns
getTimeDiff(time1, time2)
  • params
    • time1
    • time2
  • returns
getTimeSince(time)
  • params
    • time
  • returns
CAN Bus functions
initCAN(channel, baud )
  • params
  • returns
  • params
  • returns
Example:
channel = 0
id = 1234
ext = 0
data = {11,22,33}
rxCAN(channel, [timeout] )
  • params
    • timeout (optional). read timeout in milliseconds. defaults to 100ms
  • returns
Example:
  • params
  • returns
readOBD2( PID )
  • params
  • returns
Logger Control Functions
onTick()
  • params:
    • (none)
  • returns:
    • (none)
Example:
setTickRate(rate)
  • params
  • returns
    • (none)
startLogging()
Begins a logging session
  • params
    • (none)
  • returns
    • (none)
stopLogging()
  • params
    • (none)
  • returns
    • (none)
setLed( led, state )
  • params
    • led (1-3)
    • state : 1 = on, 0 = off
  • returns
    • (none)
Serial Port Communications
Port mappings
0 = USB port
1 = GPS port
3 = Wireless / Bluetooth port
4 = Auxiliary port
  • Note: We only recommend using ports 3 and 4 for connecting script to external devices. Ports 0 - 2 have been included for reference; using them may interfere with normal operations of the unit.
  • params
  • returns
readCSer( port )
  • params
  • returns
readSer( port )
available since firmware 2.8.4 Read a line of data from the specified serial port. This command blocks until a newline ('\n') character is received on the port, or a timeout occurs.
  • params
    • port: Serial port 0 - 4
writeCSer( port, data )
available since firmware 2.8.4 Writes the specified character to the serial port. The call will block until the character is written.
  • params:
  • returns:
(no return values)
writeSer( port, data )
  • params
  • returns:
(no return values)
flashLoggerCfg()
  • params
    • (none)
  • returns
    • (none)
setPwmClockFreq( freq )
  • params
  • returns
    • (none)
getPwmClockFreq()
  • params
    • (none)
  • returns
calibrateImuZero()
  • params
    • (none)
  • returns
    • (none)
Virtual Channels
available in firmware 2.0 Adds a virtual channel. This virtual channel remains in memory during runtime; it is not persisted in the configuration. Up to 30 virtual channels can be created.
  • params
  • returns
  • params
Example:
id = addChannel("EGT", 1)
   temp = temp * 1000
Time Info
getUptime()
Available in Firmware 2.8.4 and Newer
  • Returns
getDateTime()
Returns date and time info to the best of the systems ability. Only available after GPS lock has been established. Will return epoch time (Jan 1, 1970 00:00:000) if time is not available.
    • Year
    • Month
    • Day
    • Hour
    • Second
    • Millisecond
