MJLJ V3 Operation Guide
Revision as of 21:05, 25 November 2007 by Brentp (talk | contribs) (Controller options section)
First time use
Setting the Serial Port
Configuring MAP or TPS
Otherwise, select 'Forced Induction' if your engine is turbocharged or supercharged. This will set the maximum scale to 255KPa (about 21 PSI of boost)
Connecting to the MJLJ
After the COM port has beens et, connect the serial cable to the MJLJ and apply power. If you already have the MJLJ wired into your engine's wiring harness, turn the ignition key to 'on'. If you are testing the MJLJ on the bench, you can simply power the unit with a 9V battery or a suitable 9-15V power supply.
Common connection problems
Timeout reading runtime data
Could not open port
Either:
Monitoring Engine Runtime
Runtime view
Ignition Map
Editing Ignition Map
Adjusting ignition advance
  • Changing single value
  • Changing multiple cells
  • Valid Ignition Advance range: You are able to set individual cells from 0 to 59 degrees BTDC.
Adjusting Load / RPM Bins
To change the Load and RPM bins perform one of the following:
  • Ctrl-B in the main window
Controller Options
Engine Configuration
User Configurable Outputs
Output Type
Output Mode
Activation Point
The RPM or Load threshold for activating the output.
Hysteresis on outputs
Shift Light
The Shift Light output is activated when engine RPM reaches the configured threshold. Typically this output would be used to illuminate a dashboard-mounted light. For shift light wiring instructions, see the Installation Guide
Rev Limit
For instructions on wiring an external rev limit module, see the Installation Guide
Updating the Ignition Configuration
Making the changes permanent
Configuration Options
Configuring TPS
Choosing between Normally Aspirated and Forced Induction
Switchable Ignition maps
Ignition Map View
Runtime View
Tuning View
Data logging
Advanced Topics
