MJLJ V3 Operation Guide
Revision as of 21:43, 25 November 2007 by Brentp (talk | contribs) (Updated "Write/flash" ignition config section)
First time use
Setting the Serial Port
Configuring MAP or TPS
Otherwise, select 'Forced Induction' if your engine is turbocharged or supercharged. This will set the maximum scale to 255KPa (about 21 PSI of boost)
Connecting to the MJLJ
Common connection problems
Timeout reading runtime data
Could not open port
Either:
Monitoring Engine Runtime
Runtime view
To read the controller's current configuration, click the toolbar icon Mjlj read config toolbar.jpg. The current ignition configuration will be read from the MJLJ and displayed in the grid.
Ignition Map
Editing Ignition Map
Adjusting ignition advance
  • Changing single value
  • Changing multiple cells
  • Valid Ignition Advance range: Allowable ignition advance range is 0 to 59 degrees BTDC.
Adjusting Load / RPM Bins
To change the Load and RPM bins perform one of the following:
  • Ctrl-B in the main window
The Edit Ignition Bin values dialog will appear. Here, you can edit the bin values for the Load and RPM axis. Mjlj operation guide edit bin values.png
Controller Options
Engine Configuration
User Configurable Outputs
Output Type
Output Mode
Activation Point
The RPM or Load threshold for activating the output.
Hysteresis on outputs
Shift Light
Rev Limit
After editing the ignition map or controller options, you may write the changes to the controller. To do this, click the Write Ignition Configuration toolbar icon Mjlj write config toolbar.png to write your changes to the controller.
Commit to Flash
To make the changes permanent in the Controller's flash memory, Click the 'Commit configuration to Flash' toolbar icon Mjlj flash config toolbar.png. The controller will write the configuration to flash memory, and changes will be preserved after the controller loses power.
Configuration Options
Configuring TPS
Choosing between Normally Aspirated and Forced Induction
Switchable Ignition maps
Ignition Map View
Runtime View
Tuning View
Data logging
Advanced Topics
