BMW E46 Guide
Revision as of 18:15, 21 March 2016 by Brentp (talk | contribs) (Created page with "=BMW E46 (1999 to 2007)= Image:e46_race_car.jpg ==CAN bus integration== RaceCapture/Pro can integrate with the E46 proprietary (non OBD-II) CAN bus network. Additional di...")
CAN bus integration
RaceCapture/Pro can integrate with the E46 proprietary (non OBD-II) CAN bus network. Additional direct sensors for data not provided by the CAN bus connection can be connected.
Direct Sensors
Oil Pressure
You can tap into the engine TD/RPM signal from Pin 9 of the OBD-II port, available on all BMWs after 2000.
RaceCapture/Pro Timer Configuration
  • Timer Speed: Medium
  • Pulse Per Revolution: 3
