MJLJ V3 Operation Guide
First time use
Setting the Serial Port
Configuring MAP or TPS
Connecting to the MJLJ
Common connection problems
Timeout reading runtime data
Could not open port
Either:
Monitoring Engine Runtime
Runtime view
Ignition Map
Editing Ignition Map
Adjusting ignition advance
  • Changing single value
  • Changing multiple cells
  • Valid Ignition Advance range: Allowable ignition advance range is 0 to 59 degrees BTDC.
Adjusting Load / RPM Bins
To change the Load and RPM bins perform one of the following:
  • Ctrl-B in the main window
Controller Options
Engine Configuration
User Configurable Outputs
Output Type
Output Mode
Activation Point
The RPM or Load threshold for activating the output.
Hysteresis on outputs
Shift Light
Rev Limit
Commit to Flash
Additional Options
Load Axis Calibration
Guided TPS calibration
=Advanced Uses
Aside from calibrating a TPS-optioned MJLJ, you can also directly edit the load-axis calibration data. For example, if you're using a non-standard external MAP sensor you can load the sensor's voltage curve using this tool.
Load / Save calibration
Edit Values
Choosing between Normally Aspirated and Forced Induction
Switchable Ignition maps
Ignition Map View
Runtime View
Tuning View
Data logging
Advanced Topics
