BMW E46 CAN
Things you'll need
- Crimp tool
- Wire cutter
- Wire stripper
- Philipps screwdriver
- Multimeter
- 22 gauge solid wire
- RJ 45 (Ethernet) cable, ~6ft
- Shrink tubing (optional, electrical tape will work too, but not look as nice)
- Posi-tap connectors (2) - Do *not* cut the CAN wires during this installation, use wire taps (Posi-taps work very well)
- Butt connectors (2) for 22 gauge wire
- Flashlight
- RaceCapture/Pro with Bluetooth
- Android tablet
- An E46 ;)
Estimated Time
CAN wires
- Yellow/Red = CAN+ (high)
- Yellow/Brown = CAN- (low)
Remove bottom of dash
Locate CAN wires
Tapping CAN wires
Power and ground wiring
Option #1: OBD-II port power
| Connection | BMW | RaceCapture/Pro (RJ45 cable) |
| +12v | Yellow-Red (OBD-II connector) | Brown |
| Ground | Brown (OBD-II connector) | Orange/White |
| CAN High | Yellow/Red | Orange |
| CAN Low | Yellow/Brown | Green/White |
Splice power and ground wires
CAN Bus connection
- Orange: CAN1 High
- Green/white: CAN1 Low
- Brown: Power
- Orange/white: Ground
Use the following diagram:
Configure RaceCapture/Pro
Quick Start E46 configuration
Download: [File:RaceCapturePro_E46_starter_config.rcp] (right-click, save-as)
- Add your favorite race tracks for automatic detection
- Set your telemetry device id as provided by race-capture.com
Manual Setup
- Rate is 500kb/s
- Do not enable OBD-II channels.
Script
tickRate = 30
--the CAN baud rate
CAN_baud = 500000
CAN_chan = 0
--format addChannel(<name>, <sample rate>, <precision>, <min>, <max>, [units])
tempId = addChannel("EngineTemp", 1, 0, 0, 255, "F")
oilTempId = addChannel("OilTemp", 1, 0, 0, 255, "F")
steerId = addChannel("Steering", 10, 0, -360, 360, "Deg.")
brakeId = addChannel("BrakeSw", 10, 0, 0, 1)
brakePressId = addChannel("Brake", 10, 0, 0, 255, "Bar")
clutchId = addChannel("Clutch", 10, 0, 0, 1)
lfWheelId = addChannel("LFWheelSpd", 10, 0, 0, 200, "MPH")
rfWheelId = addChannel("RFWheelSpd", 10, 0, 0, 200, "MPH")
lrWheelId = addChannel("LRWheelSpd", 10, 0, 0, 200, "MPH")
rrWheelId = addChannel("RRWheelSpd", 10, 0, 0, 200, "MPH")
gearTempId = addChannel("GearboxTmp", 10, 0, 0, 400, "F")
fuelId = addChannel("Fuel", 1, 0, 0, 100, "%")
extTempId = addChannel("ExtTemp", 1, 0, 0, 120,"F")
--Convert C to F
function toF(value)
return value * 1.8 + 32
function e46_tps(value)
return value + 0.0
function rpmFilter(value)
return value
function brakeFilter(value)
return bit.rshift(bit.band(value, 0x10), 4)
function clutchFilter(value)
return bit.band(value, 0x01)
function processWheel(id, data, offset)
--wheel speed is 13 bits long, little endian
--low byte high byte
--76543210 76543210
--11111111 11111XXX
local highByte = bit.band(data[offset + 2], 0x1F)
local lowByte = data[offset + 1]
local value = highByte * 256 + lowByte
value = value * 0.0625
--convert to MPH. comment to keep KPH
value = value * 0.621371
setChannel(id, value)
function processSteering(data)
local steer = 0
if data[2] > 127 then
else
steer = (data[2]*256)+data[1]
function fuelFilter(value)
--adjust for 7 bit value
value = bit.band(value, 0x7F)
--convert liters to %. tank holds 62.83 liters
return value / 0.6283
function extTempFilter(value)
local temp = bit.band(value, 0x7F)
if value > 127 then
temp = -1 * temp
temp = toF(temp)
return temp
--format is:
--[CAN Id] = function(data) map_chan(<chan_id>, <data>, <CAN offset>, <CAN length>, <multiplier>,
-- <adder>, [filter])
CAN_map = {
[496] = function(data) processWheel(lfWheelId, data, 0)
processWheel(rfWheelId, data, 2)
processWheel(lrWheelId, data, 4)
processWheel(rrWheelId, data, 6)
end,
[339] = function(data) map_chan(brakeId, data, 0, 1, 1, 0, brakeFilter) end,
[504] = function(data) map_chan(brakePressId, data, 2, 1, 1, 0) end,
[809] = function(data) map_chan(tpsId, data, 5, 1 , 0.392156863, 0, e46_tps)
map_chan(tempId, data, 1, 1, 0.75, -48, toF)
map_chan(clutchId, data, 3, 1, 1, 0, clutchFilter)
end,
[1083] = function(data) map_chan(gearTempId, data, 0, 1, 1, -55, toF) end,
[790] = function(data) map_chan(rpmId, data, 2, 2, 0.15625, 0, rpmFilter) end,
[501] = function (data) processSteering(data) end,
[1555] = function (data) map_chan(fuelId, data, 2, 1, 1, 0, fuelFilter) end,
[1557] = function (data) map_chan(extTempId, data, 3, 1, 1, 0, extTempFilter) end
processCAN(CAN_chan)
function processCAN(chan)
local msg = 0
repeat
local id, e, data = rxCAN(chan, 0)
local map = CAN_map[id]
if map ~= nil then
map(data)
msg = msg + 1
until id == nil or msg > 100
if offset + len > #data then return end
offset = offset + 1
local value = 0
local shift = 1
while len > 0 do
shift = shift * 256
offset = offset + 1
len = len - 1
local cv = value * mult + add
setChannel(cid, cv)
initCAN(CAN_chan, CAN_baud)
Test!
Real-Time Telemetry
Just 4 wires - Power, Ground, CAN+ and CAN- is needed to stream tons of data to race-capture.com for monitoring engine, driver and suspension performance!
CAN Channel Mapping
Additional resources
- http://aimsportsystems.com.au/download/ecu/stock/bmw/BMW_Mini_100_eng.pdf - AIM docs for e46 M3 CAN codes
- http://www.diyelectriccar.com/forums/showthread.php/my-can-bus-gauge-solution-bmw-84882.html
- http://www.beisansystems.com/misc/SEIMENS_MS_420_ENGINE_CONTROL_SYSTEM.pdf
- http://www.bmwtech.ru/pdf/e46/ST034/2%20Driver%20Information%20Internet-1.pdf
- http://www.gadgetgangster.com/news/54-new-projects/556-the-car-kracker.html
- http://www.reslers.de/IBUS/index.html
- http://www.bimmerforums.com/forum/showthread.php?1887229-E46-Can-bus-project
- http://forum.e46fanatics.com/showpost.php?p=15754605&postcount=5
