RaceCapturePro Sensors
GM-Style | |||||||||||||||||
Mfg / Part # | Image | Pigtail | Mechanical | Notes | Analog Channel Configuration | ||||||||||||
AEM | |||||||||||||||||
Mfg / Part # | Image | Notes | |||||||||||||||
Mylexis MLX90620 | ![]() |
Analog Devices AD597 Type K Thermocouple amplifier | ![]() |
Low cost, easy to use thermocouple amplifier with 10mv/C temperature output directly from a K-Type thermocouple. Ideal for creating a simple thermocouple to 0-5v sensor.
Maxim MAX31851 Thermocouple amplifier | ![]() |
Versatile thermocouple amplifier with 1-wire (I2C) digital interface. Ideal for monitoring multiple sensors
These sensors are appropriate for measuring fluid pressures in an engine. Not appropriate for measuring manifold boost or vacuum as these are relative pressure sensors. Use an absolute pressure sensor instead. | |||||||||||||||||
AEM 30-2131-150 | ![]() |
3 pin GM connector | 1/8" NPT |
Various | ![]() |
3 pin GM connector | 1/8" NPT port |
3 bar MAP sensor |
Freescale MXP4250AP | 2.5 bar MAP sensor
Schrader |
RPM | |||||||||||||||||
Autosport Labs CoilX | ![]() |
The CoilX sensor module is designed to safely interface the noisy, high voltage RPM signal at the ignition coil pack primary into a clean signal that RaceCapture/Pro can process. | |||||||||||||||
Hall effect speed sensors will require an external 1K pull-up resistor, connected to 5v. This can be wired up near the sensor connection for convenience. | |||||||||||||||||
Mfg / Part # | Image | Notes | Pulse Channel Configuration | ||||||||||||||
Hamlin 55505 |
Cherry GS100701 |
Mfg / Part # | Image | Pigtail | Notes | Analog Channel Configuration | |||||||||||||
Sharp GP2D12 | ![]() |
Steps to calibrate:
Texense RHS | ![]() |
KA Sensors RHL3 | ![]() |
Various Mfg / String Potentiometer | ![]() |
String Potentiometers can be used for a variety of purposes: Linear, distance, and rotation (if cable is wrapped around a shaft) | |||||||||||||||
Ford / SMP TH45 | Screw mounted, keyed input for throttle shaft |
To calibrate, note the voltage at 0% throttle and then at 100% throttle. Use these two numbers to create a 2 point analog scaling map. |
Wiring Analog Sensors
- Input Impedance: 15K ohm
Temperature Sensor
![Temp sensor connection.png](/images/c/cf/Temp_sensor_connection.png)
Pullup resistor
Sensor Ground
Active Sensors
![Active sensor connection.png](/images/8/82/Active_sensor_connection.png)
- Power
- Ground
- Signal Output
Wiring the Speed Sensor
- Power: Connect the sensor's power to the 5v Vref on RaceCapture/Pro
- Ground: Connect the sensor's ground connection to the ground shared by RaceCapture/Pro
- Sensor Output: Connect the Sensor Output to one of RaceCapture/Pro's timer input channels
Optional pull up resistor
- Throttle Position Sensors
- Linear sensors
- String Potentiometers
Sensor Breakout Board
