MJLJ V3 Operation Guide
Revision as of 07:04, 26 November 2007 by Brentp (talk | contribs) (→Editing the Ignition Map: grammatical fix)
First time use
Setting the Serial Port
Configuring MAP or TPS
Connecting to the MJLJ
Common connection problems
Timeout reading runtime data
Could not open port
Either:
At a glance: Main Screen
Runtime Gauges
Ignition Advance
Load
Ignition Map
Editing Ignition Map
Adjusting ignition advance
  • Changing single value
  • Changing multiple cells
Adjusting Load / RPM Bins
  • Ctrl-B in the main window
Controller Options
Engine Configuration
User Configurable Outputs
Output Type
Output Mode
Activation Point
Hysteresis on outputs
Shift Light
Rev Limit
Commit to Flash
Additional Options
Load Axis Calibration
Guided TPS calibration
Advanced Uses
Load / Save calibration
Edit Values
Enabling Switchable Ignition Configurations
Enable hardware switch
Important Usage Notes
Charting / Runtime view
Tuning Perspective
The configuration software offers a 3D interactive tuner which makes it easy to interactively tune the ignition map and Load / RPM bins while the engine is running.
In this view you will see a contour plot of the ignition map, with the ignition advance as the elevation of the surface. 'Hotter' colors indicate more advance, and 'cooler' colors indicate less.
Hot Keys
Data logging
Advanced Topics
