RaceCapture-Track
Revision as of 06:34, 16 November 2016 by Brentp (talk | contribs) (→‎CAN bus)
Start it up
Plug it in
Download the app
Access the system status pages through the top left menu. The system status offers information on GPS status, current WiFi state and more. You can also get a copy of the RaceCapture application log for diagnostics. RaceCapture status page.png
Navigating dashboard screens
Setup Mode
Enabling Telemetry
Logs
Analysis Mode
Navigating data
Selecting Time vs Distance
Applying Decals
