RaceCapture-Track
Start it up
Plug it in
Download the app
Navigating dashboard screens
Setup Mode
Enabling Telemetry
Notes about Android devices
Logs
Analysis Mode
Navigating data
Selecting time vs distance
Applying Decals
More
Alternative ways to power
USB
You can power RaceCapture using the included USB cable, plugged into your car's USB charger, or you can power RaceCapture from a battery like the kind you would use to power a battery (1000 mAh or higher recommended)
Custom Cable
+12v Brown
Ground Orange/White
CAN 1 High Orange
CAN 1 Low Green/White
Recommended Tablets
Primary recommendation
Lower end recommendation
