RaceCapture-Track
Revision as of 20:21, 20 December 2016 by Brentp (talk | contribs) (USB)
Start it up
Plug it in
Download the app
Navigating dashboard screens
Setup Mode
Enabling Telemetry
Notes about Android devices
Logs
Analysis Mode
Navigating data
Selecting time vs distance
Applying Decals
More
Alternative ways to power
USB
Custom Cable
+12v Brown
Ground Orange/White
CAN 1 High Orange
CAN 1 Low Green/White
Recommended Tablets
Primary recommendation
Lower end recommendation
