MJLJ V4 Operation Guide
Revision as of 19:24, 22 September 2016 by Brentp (talk | contribs)
First time use
Minimum System Requirements
  • Windows XP or later
  • Pentium IV 1GHz
  • 256MB RAM
  • 10 MB Disk space
  • Available serial port (built in or with compatible USB-Serial Adapter)
Setting the Serial Port
USB-Serial Adapter
Configuring MAP or TPS
Connecting to the MJLJ
Serial Cable
You may construct a cable by modifying a 4 conductor modular phone cable per the wiring diagram, or you may use cable + adapter available through our online store.
Be careful to wire the actual pin number for your DB9 connector- a common mistake is to forget the pins are in reverse when soldering from the back of the connector.
Common connection problems
Timeout reading runtime data
  • Does the MJLJ have power, and connected to the computer with a standard serial cable or compatible USB-Serial adapter? See our USB-Serial adapter information page for help in selecting a compatible adapter.
Could not open port
Either:
At a glance: Main Screen
Runtime Gauges
Ignition Advance
Load
Auxiliary Input
Advance Correction
Configuring Engine Parameters
Number of Cylinders
Cranking Advance
Specify the Ignition advance used during cranking. The controller will use this value when the engine RPM is between 500 and approximately 200 RPM.
  • Note: Below 200 RPM, the EDIS module will fire the plugs at 5 to 10 degrees BTDC, regardless of Megajolt cranking advance setting.
Trigger Offset
EDIS PIP Filter Level
Ignition Map
Editing Ignition Map
Adjusting ignition advance
  • Changing single value
  • Changing multiple cells
Adjusting Load / RPM Bins
  • Ctrl-B in the main window
Advance Correction
  • Bins: The Bins determine which Advance Correction value is selected based on the value measured from the Auxiliary Input channel. You can specify a spread of values that suits your preferences, creating coarse or fine regions between bins.
  • Correction: The Ignition Advance Correction for the matching Bin. This value can be +/- 59 degrees.
  • Peak Hold: Hold the advance correction for X ignition events after a peak value is detected on the Auxiliary Input channel. After the Peak Hold decays, the Advance correction drops down to the correction value for the current Auxiliary Input value. A value of zero disables this feature.
Operation
User Output Configuration
User Configurable Outputs
Output Type
Output Mode
Activation Point
Hysteresis on outputs
Shift Light
Rev Limit
Commit to Flash
Additional Options
Load Axis Calibration
Guided TPS calibration
Advanced Uses
Load / Save calibration
Edit Values
Gauge / Label Customization
  • Auxiliary Input Label: Specify a label to match your particular use. Example: "Coolant Temp"
Edit calibration values
GM sensor Calibration File
Calibration file for the GM coolant or IAT sensor: Download
Enable hardware switch
Important Usage Notes
Charting / Runtime view
Tuning Perspective
Editing the Ignition Map
Hot Keys
Visualization
Data logging
Quick Data Logging
Mark Datalog
Stop Logging
Open Datalog
Logfile Format
  • RPM: Engine RPM
