RaceCapture-Track
Start it up
Plug it in
Download the app
- Google Play
- Amazon App Store
- Windows 10 and OSX: No drivers are needed for OSX or Windows 10.
- Windows XP, 7, 8: See the driver installation instructions below.
Setup Mode
Explanation of buttons
<img src="" width="640"/>
Enabling Telemetry
Notes about Android devices
Logs
Analysis Mode
Selecting time vs distance
Applying Decals
More
Alternative ways to power
USB
Custom Cable
Connection | RaceCapture/Pro (RJ45 cable) |
+12v | Brown |
Ground | Orange/White |
CAN 1 High | Orange |
CAN 1 Low | Green/White |
- You forgot the password you set for RaceCapture's Access Point
- You just accidentally messed something up
Steps to recover:
- Connect RaceCapture via USB
- Under Setup, adjust the WiFi settings as needed
