RaceCapturePro Sensors
GM-Style | |||||||||||||||||
AEM | |||||||||||||||||
| Mylexis MLX90620 |
3 bar MAP sensor |
| Freescale MXP4250AP | 2.5 bar MAP sensor
| Schrader |
RPM | |||||||||||||||||
| Autosport Labs CoilX |
The CoilX sensor module is designed to safely interface the noisy, high voltage RPM signal at the ignition coil pack primary into a clean signal that RaceCapture/Pro can process. | |||||||||||||||
| Mfg / Part # | Image | Notes | Pulse Channel Configuration | ||||||||||||||
| Hamlin 55505 |
| Cherry GS100701 |
| Sharp GP2D12 |
Steps to calibrate:
| Texense RHS |
| KA Sensors RHL3 |
| Various Mfg / String Potentiometer |
Air / Fuel Ratio Sensors | |||||||||||||||||
| Texense LSU 4.9 Sensor | Built-in wiring | Screws into O2 sensor port |
LSU 4.9 sensor |
Wiring Analog Sensors
- Input Impedance: 15K ohm
Temperature Sensor
Pullup resistor
Sensor Ground
Active Sensors
- Power
- Ground
- Signal Output
Wiring the Speed Sensor
- Power: Connect the sensor's power to the 5v Vref on RaceCapture/Pro
- Ground: Connect the sensor's ground connection to the ground shared by RaceCapture/Pro
- Sensor Output: Connect the Sensor Output to one of RaceCapture/Pro's timer input channels
Optional pull up resistor
- Throttle Position Sensors
- Linear sensors
- String Potentiometers
Sensor Breakout Board
