MJLJ V4 vehicle installation guide
System Overview
Parts you will need
To complete your installation, you will need the following components.
  • Throttle Position Sensor (TPS) If you chose the Megajolt with the Throttle Position Sensor input option, then you will need to supply your own TPS, if your engine does not have it already. if you chose MAP option then the Megajolt already has the MAP sensor built in.
EDIS Donor vehicles
EDIS-4 Ford Escort 1990-99 US
Ford Fiesta 1990-99 Europe
Mazda 121 1996-2001 Europe
Ford Escort 1990-2000 Europe
Ford Sierra 1990-93 Europe
Ford Explorer 1990-97 US
Mazda Navajo 1990-97 US
Ford Aerostar 1990-97 US
Lincoln Town Car 1990-97 US
Ford Thunderbird 1990-97 US
Mercury Cougar 1990-97 US
Ford Mustang 5.0 1990-97 US
  • Component Suppliers
Ford EDIS component suppliers
Location Company
USA Boost Engineering
UK Trigger Wheels
EDIS installation
Sensor Position
EDIS-4 90 9
EDIS-6 60 6
EDIS-8 50 5
Typical Trigger Wheel Installation
Installation and Sensor Gap
Megajolt Lite Jr. Wiring
Minimal Wiring for operation
MAP Sensor operation
TPS Sensor operation
Interfacing to Tachometers
Smiths RVI type tachometers
Note that there are two types of older Smiths tachometers: RVI - current sensing, and RVC - voltage sensing. These letters, and numbers indicating exactly which variant you have, are printed in small white lettering on the bottom of the face of the tachometer. RVI type tachometers work by routing the coil +ve supply wire through an inductive loop of wire inside the tachometer, and are not compatible with the MJLJ tach out signal or the tach out signal from the EDIS control module. If you have an RVI type tachometer, you can try routing the power wire for the EDIS coil pack only through the tachometer so the induction windings in the tach can pick up the spark firing events like the OEM system. This has been tested on a 4 cylinder British car with an OEM RVI tach and it gave excellent results. Other options are you replace the tach with a different type, have an add-on circuit board added inside (or build one yourself, see http://www.dinoplex.org/tachoconversion for a start), or replace all the inside working parts with those from a newer tachometer ie retain the original face, but change everything else. For that approach you need a donor which has the same angular swing per 1000rpm, as the Smiths gauge.
User Defined Outputs and Shift Light
Usage
Enabling Option Switch
Rev Limit control
Hard Rev Limit
Soft Rev Limit
Auxiliary Input
Analog input source
Hardware Modification
MJLJ Operation
Verification Steps
Verifying MJLJ operation
Verifying Power
Verifying Signals
Expected Voltages
* 0 volts when not running;
* 0V when engine not running;
