BMW E36 Guide
BMW E36 (1990 - 1999)
- Timer Mode: RPM
- Timer Speed: Medium
- Pulse Per Revolution: 3
TPS
- 0.62 volts at 0% throttle
- 4.64 volts at 100%
Engine Temperature
In research
Should be similar to E30
Fuel Level
Mapping in RCP
- 0.2v = 0 (empty)
- 1.33v = 25 (1/4)
- 2.2v = 50 (half)
- 2.95v = 75 (3/4)
- 3.53v = 100 (full)
You may want to average your fuel readings to compensate for slosh.
(Needs verification)
- 0 ohms empty
- ?? ohms 1/4
- ?? ohms 1/2
- ?? ohms 3/4
- 260 ohms full
Oil Pressure
You can get a few channels from the OBDII port of the E36 using the ASL Legacy OBDII Cable, but it is fairly slow to update. Useful channels are RPM, EngineTemp, and TPS. See the Enabling OBD-II Guide. It is also possible to read and clear OBDII codes via Lua Script.
Available Sensors:
- RPM
- EngineTemp
- TPS
- IAT (needs to be converted to F)
- WheelSpeed (needs to be converted to MPH)
- MAF
- EngineLoad
- FuelFlowRate
- Timing
Assumes:
- Pin 10 on radio connector
setTickRate(10) --10Hz
--virtual channels
--global constants
first = 4.20
second = 2.49
third = 1.66
fourth = 1.24
fifth = 1.00
final = 3.46
tirediameter = 24.7
--global variables
rpm = 0
rpm_diff = 0
speed = 0
function updateSpeedDiff()
rpm_diff = getTimerRpm(1)
function updateGear()
rpm = getTimerRpm(0)
local gearErr = 0.15
local gear = 0
if speed > 2 then
ratio = rpm/(rpm_diff*final)
if ((first - ratio)^2) < (gearErr^2) then gear = 1 end
if ((third - ratio)^2) < (gearErr^2) then gear = 3 end
if ((fifth - ratio)^2) < (gearErr^2) then gear = 5 end
setChannel(gear_id, gear)
updateSpeedDiff()
updateGear()
