BMW E36 Guide
BMW E36 (1990 - 1999)
- Timer Mode: RPM
- Timer Speed: Medium
- Pulse Per Revolution: 3
TPS
- 0.62 volts at 0% throttle
- 4.64 volts at 100%
Engine Temperature
In research
Should be similar to E30
Fuel Level
Mapping in RCP
- 0.2v = 0 (empty)
- 1.33v = 25 (1/4)
- 2.2v = 50 (half)
- 2.95v = 75 (3/4)
- 3.53v = 100 (full)
Brake Light
- Tap the Blue/Red wire coming out of the brake light switch on the back of the brake pedal. Wire this to a digital input of RCP. Note: Must use a 10k Ohm Resister between RCP and brake light wire.
- Can be helpful to know when the driver actually applies the brakes for data analysis of the driver. This gives you a simple yes/no of whether the driver is on the brakes. Lets you know exactly when they applied the brakes. Use this in conjunction with TPS to see how much time they are 'coasting'.
Oil Pressure
You can get a few channels from the OBDII port of the E36 using the ASL Legacy OBDII Cable, but it is fairly slow to update. Useful channels are RPM, EngineTemp, and TPS. See the Enabling OBD-II Guide. It is also possible to read and clear OBDII codes via Lua Script.
Available Sensors:
- RPM
- EngineTemp
- TPS
- IAT (needs to be converted to F)
- WheelSpeed (needs to be converted to MPH)
- MAF
- EngineLoad
- FuelFlowRate
- Timing
Assumes:
- Pin 10 on radio connector
setTickRate(10) --10Hz --virtual channels --addChannel("name",SR,prec,min,max,"unit") speeddiff_id = addChannel("Speed_",10,0,0,160,"MPH") gear_id = addChannel("Gear_",5,0,0,5,"gear") --global constants --edit these to match your car first = 4.20 second = 2.49 third = 1.66 fourth = 1.24 fifth = 1.00 final = 3.46 tirediameter = 24.7 --global variables rpm = 0 rpm_diff = 0 speed = 0 function updateSpeedDiff() rpm_diff = getTimerRpm(1) speed = rpm_diff*tirediameter*0.002975 speed = speed + 0.5 -- round because 0 prec. truncates setChannel(speeddiff_id, speed) end function updateGear() rpm = getTimerRpm(0) local gearErr = 0.15 local gear = 0 if speed > 2 then ratio = rpm/(rpm_diff*final) if ((first - ratio)^2) < (gearErr^2) then gear = 1 end if ((second - ratio)^2) < (gearErr^2) then gear = 2 end if ((third - ratio)^2) < (gearErr^2) then gear = 3 end if ((fourth - ratio)^2) < (gearErr^2) then gear = 4 end if ((fifth - ratio)^2) < (gearErr^2) then gear = 5 end end setChannel(gear_id, gear) end function onTick() updateSpeedDiff() updateGear() end
