ShiftX2
In the kit you will receive:
  • ShiftX2 module
  • 4 wire pigtail
  • Acrylic enclosure
Dimensions
  • ShiftX2 bare board: 143 x 85mm (5.6 x 3.27 inches)
  • ShiftX2 enclosure: 172 x 18 x 12.7 mm (6.x8 x 0.71 x 0.5 inches)
Assembling the enclosure
Mounting ShiftX2
Pinout
Orientation is left to right looking into board connector:
Color Assignment Notes
Red 9-12v Power Connect this to switched ignition power. 0.5A max consumption.
Black CAN High
Yellow CAN Low
White Ground
Integration with RaceCapture / PodiumConnect
We recommend connecting ShiftX2 to CAN2 of your RaceCapture or PodiumConnect system.
Direct Wiring
For RaceCapture/Pro MK3, RaceCapture/Apex and PodiumConnect, we recommend direct wiring to the CAN bus connections provided by your system.
For RaceCapture/Pro MK2 or RaceCapture/Track MK2 using the RJ45 connector, you can use a commonly available RJ45 splitter and RJ45 network-style extension cables to conveniently connect both OBDII and ShiftX2 on the same connector. With ShiftX2 on CAN2, the OBDII port is free to continue to use CAN1, and ShiftX2 will receive power from the OBDII port.
Suggested parts:
  • RJ45 Splitter "Hub" shaped
Patching the RJ45 cable to ShiftX2
You will need to splice ShiftX2 to the conductors of the patch cable. Start by snipping the RJ45 connector off the end of a patch cable, and then expose the individual wires.
ShiftX2 connection RaceCapture Connection CAT5 EIA-T568B RJ45 cable
Red +12v Brown
White Ground Orange/White
Black CAN 2 High Blue
Yellow CAN 2 Low Blue/White
Power
  • Note: You can use the same circuit for your RaceCapture system so they power up simultaneously.
CAN bus connections
  • Note: You can choose either CAN1 or CAN2 to drive ShiftX2. The CAN bus can be defined in the script you use to control ShiftX2.
Using ShiftX2
The LEDs and display on ShiftX2 are controlled by RaceCapture's Lua scripting capabilities. Built-in functions provide access to ShiftX3's capabilities. See the ShiftX2 Lua scripting reference for additional details.
Compatibility
ShiftX2 works with the following devices:
  • RaceCapture/Pro MK2
  • RaceCapture/Pro MK3
  • RaceCapture/Apex
  • RaceCapture/Track MK2
  • PodiumConnnect
Firmware Requirements
ShiftX2 requires RaceCapture/PodiumConnect firmware 2.15.0 or higher. Download the latest firmware
Navigation Buttons
Once ShiftX2 is powered and connected via CAN bus to your RaceCapture system, the left button will automatically trigger a page navigation on the RaceCapture app dashboard.
Disco Lights Demo
Script
function rndc()
  return math.random(0,255)
  for i=0,9,1 do
Sequential shift light
Script
setTickRate(30)
-- can bus: 0=CAN1, 1=CAN2
sxSetConfig(0,0,1)
--config shift light
Assumptions:
Script
setTickRate(30)
sxSetConfig(0,0,1)
  --update RPM
  --update engine temp alert
  --update oil pressure alert
Script
-- Predictive time visualizer
--save best lap time
bestTime = 0
sxSetConfig(0,0,1)
setTickRate(30)
  -- rail values
  sxUpdateLinearGraph(timeDiff)
Boost Gauge
Assumptions
  • MAP sensor channel is on the first Analog channel, and reads in KPa - typically 0-255. You can also connect this to the MAP reading on OBDII (PID 11)
Script
setTickRate(30)
sxSetConfig(0,0,1)
  local map = getChannel("MAP")
  if map ~= nil then
    --convert to PSI boost
    sxUpdateLinearGraph(boost)
Manual control of ShiftX2
You can obtain low level control ShiftX2 by sending it direct CAN messages in Lua scripting. This is primarily useful if controlling a second ShiftX2 if that is running on the alternate CAN ID.
  • Note: The built-in firmware support for ShiftX2 is focused on controlling one ShiftX2 in your system. - you can use a combination of the built-in functions to control the primary ShiftX2, and then direct CAN control for the second unit.
Example starter script that shows how to directly control ShiftX2:
sxCan = 0
sxId=0
tickRate=30
sxBright=0
function sxOnUpdate()
function sxOnInit()
function sxOnBut(b)
  println('button: ' ..b)
---ShiftX2 functions
--Set an individual LED
--red: Red value (0-255)
--green: Green value (0-255)
--blue: Blue value(0-255)
--blue: Blue value (0-255)
--alertId: Alert Id to set
--currentValue: Updated value
--Configures the linear graph
--End reference
  sxTx(10,{i,l,r,g,b,f})
  sxTx(3,{bright})
  sxTx(20,{id,r,g,b,f})
function sxUpdateAlert(id,v)
  sxTx(42,{spl(v),sph(v)})
function sxInit()
  println('config shiftX2')
  setBaseConfig(sxBright)
function sxChkCan()
  id,ext,data=rxCAN(sxCan,0)
function sxProcess()
  sxChkCan()
function sxTx(offset, data)
  sleep(10)
  sxProcess()
sxInit()
ShiftX2 CAN bus API
Offset What Value
Offset What Value
Offset What Value
Set Discrete LED
CAN ID: Base + 10
Offset What Value
2 Red 0 - 255
3 Green 0 - 255
4 Blue 0 - 255
5 Flash 0-10Hz (0 = full on)
Alert Indicators
Set Alert
CAN ID: Base + 20
Offset What Value
1 Red 0 - 255
2 Green 0 - 255
3 Blue 0 - 255
4 Flash 0-10Hz (0 = full on)
Set Alert Threshold
CAN ID: Base + 21
Offset What Value
1 Threshold ID 0 - 4
2 Threshold (low byte)
3 Threshold (high byte)
4 Red 0 - 255
5 Green 0 - 255
6 Blue 0 - 255
Update Current Alert Value
CAN ID: Base + 22
Offset What Value
1 Value (low byte)
2 Value (high byte)
Linear Graph
  • Linear style: stepped
  • Low Range: 0
  • High Range: N/A
  • Threshold :
Configure Linear Graph
Rendering style:
Linear style:
CAN ID: Base + 40
Offset What Value
2 Low Range (low byte)
3 Low Range (high byte)
Set Linear Graph Threshold
CAN ID: Base + 41
Offset What Value
0 Threshold ID 0 - 4
4 Red 0 - 255
5 Green 0 - 255
6 Blue 0 - 255
CAN ID: Base + 42
Offset What Value
0 Value (low byte)
1 Value (high byte)
Notifications
Button State
CAN ID: Base + 60
Offset What Value
