RaceCapturePro Sensors
GM-Style | |||||||||||||||||
Mfg / Part # | Image | Pigtail | Mechanical | Notes | Analog Channel Configuration | ||||||||||||
AEM | |||||||||||||||||
Mfg / Part # | Image | Notes | |||||||||||||||
These sensors are appropriate for measuring fluid pressures in an engine. Not appropriate for measuring manifold boost or vacuum as these are relative pressure sensors. Use an absolute pressure sensor instead. | |||||||||||||||||
AEM 30-2131-150 | 3 pin GM connector | 1/8" NPT |
Various | 3 pin GM connector | 1/8" NPT port |
3 bar MAP sensor |
Freescale MXP4250AP | 2.5 bar MAP sensor
Schrader |
RPM | |||||||||||||||||
Autosport Labs CoilX | The CoilX sensor module is designed to safely interface the noisy, high voltage RPM signal at the ignition coil pack primary into a clean signal that RaceCapture/Pro can process. | ||||||||||||||||
Hall effect speed sensors will require an external 1K pull-up resistor, connected to 5v. This can be wired up near the sensor connection for convenience. | |||||||||||||||||
Mfg / Part # | Image | Notes | Pulse Channel Configuration | ||||||||||||||
Hamlin 55505 |
Cherry GS100701 |
Mfg / Part # | Image | Pigtail | Notes | Analog Channel Configuration | |||||||||||||
Sharp GP2D12 |
Steps to calibrate:
Texense RHS |
KA Sensors RHL3 |
Various Mfg / String Potentiometer |
Ford / SMP TH45 | Screw mounted, keyed input for throttle shaft |
Air / Fuel Ratio Sensors | |||||||||||||||||
Texense LSU 4.9 Sensor | Built-in wiring | Screws into O2 sensor port |
LSU 4.9 sensor |
Wiring Analog Sensors
- Input Impedance: over 1 meg ohm
Calibrating an Analog Sensor
Refer to your sensor's data sheet for the sensor's calibration curve.
Linear Sensors
A linear sensor may specify two voltages/value pairs representing a low and high range for the sensor. A straight line is drawn between the points on the sensor.
Example: 150 PSI pressure sensor
- 0.5 v = 0 PSI
- 4.5 v = 150 PSI
Curved Sensors
These are often seen with thermistor based temperature sensors, where the response is not a straight line, but a curve. Multiple points can be used to sufficiently approximate the curve.
- Note: RaceCapture will linearly interpolate the scaled values between the sensor points, so value transitions will be smooth.
Example: Extended Range temperature sensor with 5v reference and 2.2K pullup resistor
- 0.4 v = 302 F
- 0.87 v = 239 F
- 1.88 v = 176 F
- 3.2 v = 122 F
- 4.72 v = 32 F
- Note: If you have more than 5 points for the curve, spread the selection of points evenly between your low and high range.
Types of Sensors
Temperature Sensor
Pullup resistor
Sensor Ground
Active Sensors
- Power
- Ground
- Signal Output
Wiring the Speed Sensor
- Power: Connect the sensor's power to the 5v Vref on RaceCapture/Pro
- Ground: Connect the sensor's ground connection to the ground shared by RaceCapture/Pro
- Sensor Output: Connect the Sensor Output to one of RaceCapture/Pro's timer input channels
Optional pull up resistor
- Throttle Position Sensors
- Linear sensors
- String Potentiometers
- Fuel Level Sensors
Standard Variable Resistor (Potentiometer)
These are typically found in Throttle Position Sensors (TPS), string potentiometers, and linear sensors.
Fuel Level Sensors
Also a variable resistor, these provide a variable resistance based on the level of the float.
If you already have a gauge connected
You will not need a pullup resistor - the gauge's internal circuitry already provides one. You will only need to tap into the existing signal feeding the fuel gauge sender. Jump to the calibration process below.
- Note you will need to ensure the sender does not exceed 5v during calibration. if it does, you will need an additional voltage divider to scale the voltage down to 0-5v required by the RaceCapture input.
If you have no gauge / you want to only use RaceCapture for your dashboard gauge
If you only have the sender and want to directly integrate with RaceCapture's analog input, follow this procedure.
- Choose a pull-up resistor value based on the the sender's ohm range. If it is less than 1000 ohms, then choose a 1000 (1K) ohm resistor as your pull-up. If the sender range is higher than 1000 ohms, choose a 2.2K resistor.
- Rule of thumb - choose a resistor that is about 2X to 4X the maximum resistance of the sender.
- A 1/2 watt, 1% accuracy resistor is recommended.
Calibration
- Empty (0%)
- 1/4 (25%)
- 1/2 (50%)
- 3/4 (75%)
- Full (100%)
Set up the Analog Channel
- Choose an available analog input for your Fuel Level channel, then select the basic fuel level preset by selecting FuelLevel in the dropdown list.
- This pre-sets the units (%), logging precision and min / max values. You can edit this by pressing the gear button next to the channel name.
- Set the sample rate to 1Hz.
Sensor Breakout Board
