GPIO Output
GPIO Output to control switches, relays, LEDs, etc
Relays
If you have a device you want to control that requires more than 1A, you will need to use a Relay to power it. Normally a SPST relay would have a constant 12v, constant Ground, 12v Output, and input 12v that triggers the relay and sends 12v to the Output. To control a standard 4 pin SPST Relay with Race Capture Pro, You would have constant 12v, but instead of switched 12v input, that will now also always be hot, and instead of constant ground, you will have switched ground controlled by the RCP. When you set the GPIO to active it will ground the relay, triggering it and send 12v power to your desired device.
LEDs
Most small LED indicator lights can be controlled directly with RCP. Wire power directly to the LED, and wire the ground to the GPIO of the Race Capture Pro. Triggering the GPIO of the RCP will ground the LED turning it on.
Lua Scripting for GPIO's
In order to turn on a GPIO you need to do so with in the Lua script. Once turned on(ie. setGpio(1,1) , it will stay on until you explicitly turn it off (ie. setGpio(1,0)
setGpio ( channel, state )
- params
- channel: integer 0 - 2
- returns:
- none
See the Race Capture Pro Lua Scripting GPIO section for more info.
