MJLJ V4 Operation Guide
Revision as of 09:18, 2 June 2008 by Brentp (talk | contribs) (→Charting / Runtime view: updated image for V4)
First time use
Setting the Serial Port
Configuring MAP or TPS
Connecting to the MJLJ
Common connection problems
Timeout reading runtime data
Could not open port
Either:
At a glance: Main Screen
Runtime Gauges
Ignition Advance
Load
Ignition Map
Editing Ignition Map
Adjusting ignition advance
  • Changing single value
  • Changing multiple cells
Adjusting Load / RPM Bins
  • Ctrl-B in the main window
Controller Options
User Configurable Outputs
Output Type
Output Mode
Activation Point
Hysteresis on outputs
  • Auxiliary configured outputs: Hysteresis is set at 1 Unit.
Shift Light
Rev Limit
Commit to Flash
Additional Options
Load Axis Calibration
Guided TPS calibration
Advanced Uses
Load / Save calibration
Edit Values
Enable hardware switch
Switching between ignition configurations requires wiring the option switch to the Controller. Refer to the [Guide] for more information.
Important Usage Notes
Tuning Perspective
Editing the Ignition Map
Hot Keys
Data logging
Quick Data Logging
Mark Datalog
Stop Logging
Logfile Format
  • RPM: Engine RPM
Advanced Topics
