AutomaticCameraControl
Revision as of 18:23, 17 May 2020 by GTIspirit (talk | contribs) (Initial page for Garmin Virb camera control)
Automatic Camera Control
This guide shows you how to enable automatic start / stop control of WiFi enabled cameras, such as GoPro using RaceCapture or PodiumConnect.
Most action cameras offer a WiFi interface for remote control. GoPro is one such camera, and allows shutter control via the WiFi interface, which RaceCapture or PodiumConnect can leverage for automatic triggering.
Currently supported versions of RaceCapture hardware
  • PodiumConnect
  • RaceCapture/Apex
  • RaceCapture/Pro MK3
  • RaceCapture/Track MK1 and MK2
  • RaceCapture/Pro MK2 with external WiFi add-on (see below)
Currently supported cameras
  • GoPro Hero 2/3
  • GoPro Hero 4/5 (experimental)
  • Garmin Virb Ultra 30 (experimental)
Note, We recommend GoPro 2/3 due to stability / reliability issues seen with the later GoPro devices.
Additional Camera support will be added with future firmware releases.
RaceCapture or PodiumConnect is configured so it's WiFi client connects to the camera's access point using its SSID and WiFi password.
When RaceCapture/PodiumConnect triggers the camera based on a sensor threshold such as speed, RPM or other value, it sends a command to the camera to start recording. When the sensor falls below the threshold, the corresponding command is sent to stop the recording.
Simultaneous WiFi connection with the RaceCapture App
Since the WiFi client feature is used on RaceCapture/PodiumConnect to connect to the camera, the Access Point remains available for the RaceCapture app to connect via WiFi, as usual. Or, via Bluetooth, if supported by the RaceCapture system.
Setting up Automatic Camera Control
Applies to
  • PodiumConnect
  • RaceCapture/Apex
Requirements
  • Firmware 2.13.0 or higher
Set up WiFi client
Navigate to Setup / Wireless and ensure:
  • WiFi is turned ON
  • WiFi client is turned ON
  • Camera SSID and password are specified in the WiFi client settings.
Set up Automatic Control
Navigate to Setup / Automatic Control and ensure:
  • The desired sensor channel trigger is selected (Speed is the default)
  • Your start / stop and time thresholds are configured
  • Camera Control is turned ON and you have your camera model selected.
Write Settings
Testing
Turn on the camera and ensure the camera has it's WiFi interface enabled.
It may take several seconds for the client to connect. If not, re-check the camera's SSID/password, and ensure WiFi is enabled on the camera.
  • Note: On GoPros, the Camera must be in 'App mode' with WiFi enabled.
Once it is connected to the camera, you can test the camera by triggering the configured camera's threshold.
  • Tip: For static testing, you can configure the camera control to one of the Accelerometer channels, such as AccelZ and trigger by inverting RaceCapture. Or, use RPM, battery voltage or similar.
RaceCapture/Pro MK2
While the automatic camera control firmware feature is not available for RaceCapture/Pro MK2, it can still be controlled via a Lua script.
When WiFi is enabled on your GoPro camera it creates a network that other devices can connect to. A WiFi enabled version of RaceCapture/Pro can connect to this network and issue the appropriate commands to control various camera functions - in this case, starting and stopping video recording.
Starting and stopping the GoPro can be controlled by a variety of means: speed, RPM or based on other sensor data, enabled by a Lua Script running on RaceCapture/Pro.
Notes
  • Currently, the WiFi module can only be used to enable GoPro triggering.
  • If running firmware version 2.10.x or higher To use this script, you must disable the built-in WiFi control, or else it will take over the connection and block the script from running.
  • Future versions of RaceCapture firmware and app will allow built-in firmware control of GoPro cameras, which will eliminate the need for this script.
Requirements
  • RaceCapture/Pro WiFi module
  • WiFi enabled GoPro Hero camera, with WiFi activated
  • GPS Connectivity (for speed measurement)
Steps
Configure your GoPro
Connect the WiFi module
  • When powered up, you should see the power LED illuminate.
  • This port is to the right of the Bluetooth Port.
    • The WiFi module does not interfere with the operation of the Bluetooth module.
Steps:
Bench testing
  • Tip 1: Touch or click the Poll Log to see the current message in the RaceCapture/Pro log
  • Tip 2: To restart the Lua script, touch or click the 'Restart' button.
Road testing
  • Drive carefully above the speed threshold and observe the GoPro - you should hear and see the familiar beep and red light activate, just as if you manually started recording using the shutter button on the camera.
  • When you drop below the threshold, the GoPro should stop recording.
[GoProWiFi] start GoPro
[GoProWiFi] stop GoPro
  • GoPro WiFi network name (SSID) and password: Ensure the name and password currently in the script matches how your GoPro was configured.
  • Enable WiFi on the GoPro: The blue LED on the GoPro should be blinking periodically
  • RaceCapture/Pro WiFi module connection: Ensure the module is plugged into the outermost RJ11 port and the green LED is illuminated.
  • Verify WiFi connection: Ensure RaceCapture/Pro can connect to the GoPro WiFi network. You should see the following messages in the log upon power-up:
[lua] Successfully loaded script.
[GoProWiFi] initializing
[GoProWiFi] ready for GoPro
[GoProWiFi] could not connect to GoPro
Lua Script for GoPro
Customization
Required
Optional
goproPwd = '12345678'
goproSsid = 'aslhero1'
goproStart = 10
goproStop = 5
--How fast we check, in Hz
tickRate = 10
debug = 0
--DO NOT EDIT BELOW
port = 4
--indicates wifiStatus
wifiStatus = 0
lastInitTime = 0
initTimeout = 20000
function logMsg(msg)
  println('[GoProWiFi] ' ..msg)
function sendCrlf()
  writeCSer(port, 13)
  writeCSer(port, 10)
function sendRaw(val)
  for i=1, #val do
function sendAt(val)
  sendRaw(val)
  sendCrlf()
function toInt(val)
  return string.sub(val, 1, -3)
function httpGet(url)
  sleep(500)
  sleep(100)
  sendRaw(get)
  sleep(100)
  sendAt("AT+CIPCLOSE")
function startGoPro()
  logMsg('start GoPro')
  sendGoProShutter('01')
function stopGoPro()
  logMsg('stop GoPro')
  sendGoProShutter('00')
recording = 0
function initWiFi()
  logMsg('initializing')
  sendAt('AT+RST')
  sleep(2000)
  sendAt('AT+CWMODE_CUR=1')
  sleep(1000)
  wifiStatus = 1
function processIncoming()
    wifiStatus = 2
    wifiStatus = 3
    logMsg('ready for GoPro')
function checkGoPro()
  if wifiStatus == 0 then
    initWiFi()
    lastInitTime = getUptime()
    return
    wifiStatus = 0
  processIncoming()
  if wifiStatus ~= 3 then
    return
  trigger = getGpsSpeed()
    startGoPro()
    recording = 1
    stopGoPro()
    recording = 0
  checkGoPro()
Lua Script for Garmin Virb
The following Lua Script enables WiFi control of your Garmin Virb camera.
Customization
Required
  • Ssid: Specify the WiFi network name (SSID)
  • Pwd: Specify the WiFi password
Optional
  • autoStart: Change this if you want to start recording at a different threshold.
  • autoStop: Change this if you want to stop recording at a different threshold. Ensure this is less than the start trigger
setTickRate(10) --TickRate is in Hz
--configure WiFi serial port
port = 5
initSer(port,115200,8,0,1)
--Specify client SSID here
Ssid = 'VIRB-4615'
--Specify client wifi password here
Pwd = '12345678'
debug = 0
--initialize variables
trigger = 0
recording = 0
--define constants
autoStart = 0  --Threshold to start recording
autoStop = 1  --Threshold to stop recording
------WiFi Code--------------
--DO NOT EDIT BELOW
wifiStatus = 0
lastInitTime = 0
initTimeout = 20000
reps = 3 --number of times to repeat command
  println('[WiFi] ' ..msg)
function sendCrlf()
  writeCSer(port, 13)
  writeCSer(port, 10)
  for i=1, #val do
  sendRaw(val)
  sendCrlf()
function toInt(val)
function httpPost(cmd)
  sendAt('AT+CIPSTART="TCP","192.168.0.1",80')
  sleep(500)
  local post = 'POST /virb HTTP/1.1\r\nHost: 192.168.0.1\r\nAccept: */*\r\nContent-Length: ' ..toInt(#cmd)..'\r\nContent-Type: application/x-www-form-urlencoded\r\n\r\n' ..cmd ..'\r\n' ..crlf ..crlf
  sendAt('AT+CIPSEND=' ..toInt(#post))
  sleep(100)
  sendRaw(post)
  if debug == 1 then println(post) end
  sleep(100)
  sendAt('AT+CIPCLOSE')
function initWiFi()
  sendAt('AT+RST')
  sleep(2000)
  sleep(1000)
  sendAt('AT+CWJAP_CUR="' ..Ssid ..'","' ..Pwd ..'"')
  wifiStatus = 1
  if string.match(line, 'WIFI GOT IP') or string.match(line, 'WIFI CONNECTED') then
    wifiStatus = 2
    wifiStatus = 3
    logMsg('ready for WiFi')
function checkWiFi()
    initWiFi()
    return
    logMsg('could not connect to WiFi')
    wifiStatus = 0
  processIncoming()
    return
  --trigger = getGpsSpeed()
  trigger = bit.rshift(bit.band(getChannel("77AB2"),0x40),6)
  --trigger = 1
  if recording == 0 and trigger > autoStart then
    for i=1,reps,1
    do
    httpPost('{"command":"startRecording"}')
    recording = 1
  if recording == 1 and trigger < autoStop then
    for i=1,reps,1
    do
    httpPost('{"command":"stopRecording"}')
    recording = 0
  checkWiFi()
  println('trigger value: ' ..trigger)
  println('recording status: ' ..recording)
  if debug ==1 then println("WiFi Status: " ..wifiStatus) end
